Hi all,
My chain cuts in my frontsprocket cover
. It is a CB750K7, with a 630 chain. My old chain did it, and my brand new chain do it
also.
I have the back wheel in-line, the chain seems to be in-line, in fact... everything seems to be in-line.
There are 2 things I'm thinking of,
- How is the front sprocket mounted? There is a "hub" on one side of the sprocket. Since the old sprocket was mounted with the "hub" on the engine/gear side i mounted the new sprocket the same way. Is this the correct way?
- a few months ago i replace the rearwheel bearings, I'm sure i mounted everything the correct way. But maybe there is something changed and the rearsprocket has changed position a little.
Is there anybody here who can tell me if these measures are correct?
frontsprocket = 29,7 mm
rearsprocket = 23,5 mm
thanks!
