Author Topic: carb rebuild clarification  (Read 1334 times)
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« on: July 15, 2011, 09:25:17 AM »
Hey folks. Rebuilding a set of carbs for my '76 550k. I am putting all new o-rings in, and need to know if it's normal for the main jet to sit loosely on top of the emulsion tube. I know the wing spring holds it in place - but when removing them, they were seated in there securely. Is that just because the old corrosion and o-ring shrinkage?
Also, in the photo below, there are 4 larger o-rings at the top. I'm pretty sure that they belong on the 2 couplers between carbs 1&2 and 3&4, but I think it only needs a total of 8, and with this kit set (4) it would total 16. Am I missing something, or are they just providing extras?
Thanks
« Last Edit: July 15, 2011, 07:57:14 PM by Nortstudio »
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline Bankerdanny
  • Endeavor to persevere
Re: carb rebuild calcification
« Reply #1 on: July 15, 2011, 09:37:01 AM »
I believe that the kits include o-rings for both sides of the connector tubes under the theory that you might only be fixing one carb, but would want to replace the o-rings on both sides of the connector.
I ended up with several spare o-rings when I did the carbs on my '77.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #2 on: July 15, 2011, 09:47:29 AM »
Thanks Danny. I figured that was it, but wanted to make sure I didn't end up spewing gas out of unsealed orafices :)
Do you have the push in style jet?  Know if it's supposed to be sitting loosely???
Appreciate the help.
~Sophocles
Offline Deltarider
  • I'm back
« Reply #3 on: July 15, 2011, 10:21:23 AM »
Here's why http://forums.sohc4.net/index.php?topic=90925.msg1017309#msg1017309
CB500K2-ED Excel black
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #4 on: July 15, 2011, 10:43:33 AM »
I remembered you had asked about that delta. This kit came with all of them - a full 4 per kit. It's labeled 16010-323-315
~Sophocles
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #5 on: July 15, 2011, 10:59:32 AM »
You only need 8 of the fuel coupler o-rings total. They just give extras. Your main jet should actually push in pretty snug with new o-rings. Not loose at all. Sure you have the right o-ring? Trying to jog my memory on where the other three go. I think the smallest one goes on the bowl drain screw. The other two will be a sample fit for you. I matched all old o-rings with the new ones as I installed them. I also used Permatex #2 to hold the bowl o-ring in place. It's pliable and fuel resistant. Just use enough to hold it but not enough to squeaze out anywhere.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #6 on: July 15, 2011, 11:54:57 AM »
I'm pretty sure he main jet gets the smallest one. The other small one, but fatter goes on the drain screw. That next size up goes on the needle seat.
No other one felt right on the main jet. The emulsion tube seems like it's in as far as it can go, but still they are lose. They sit in there ok, and then are held in by the wing spring and float. All 4 of them are exactly the same. Not sure what I'm doing wrong here.
I didn't take enough notes/pics, because I have a whole set sitting next to me, which I had planned on using for reference - but have not been able to take ANY of it apart, because of such heavy oxidation and corrosion. Bad move!
~Sophocles
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #7 on: July 15, 2011, 01:12:46 PM »
I am in a deep, dark place right now my friends. Had to end up swapping out several parts from the corroded rack onto te newer one I just got (and have been cleaning) because they were incomplete.
Just about done and realized I needed a replacement arm/cam that plunges the needle, as well as a missing MAIN SPRING!  Ugh. The PO told me they came off a running bike. Good grief!
~Sophocles
« Reply #8 on: July 15, 2011, 01:17:25 PM »
The emulsion tube must be fully seated into the carbs  They stand a bit proud of the carb bore.
The main jet should have full contact with the base of the emulsion tube.  Make certain you aren't putting the jet in upside down.  You should be able to read the jet numbers when installed.  New orings  Have to be squashed some in order to seal correctly.  Don't do this dry, or the orings can be abraded/nicked.  Vaseline or other GP grease can be used to ease the jet into fully seated position while compressing the jet orings.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #9 on: July 15, 2011, 01:52:25 PM »
Ok. I will check that out when I open the floats again. I just got finished attaching the carbs back to the rack holder. Man!  I now understand why people suggest not removing the carbs from the rack. :)
I had to do it - and I'm glad that one day, probably 47 days from now, I'll be able to look back and say " I'm glad that's finished."
~Sophocles
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #10 on: July 15, 2011, 02:19:56 PM »
The jets now seem seated well. I guess the pressure of closing them up made them sit nice. One was a little less "stuck" in there but seemed ok. I will keep an eye on that one when fuel starts flowing.
This is how she looks...
Thanks for all your help folks.
~Sophocles
