Author Topic: Mercury in oil pan?  (Read 2084 times)
Offline Rgconner
Mercury in oil pan?
« on: July 26, 2011, 06:03:06 PM »
Pulled the oil pan to check the screen and make sure it was not clogged with cork from a failed clutch plate.
What I did find was what looked like mercury beads in the bottom. Bright, silvery and split when tapped with a screwdriver.
Looked to be about what would be in a mercury switch, or less.
Any ideas?
1975 CB550K aka "Grease Monkey"
Offline hondamatteo
Re: Mercury in oil pan?
« Reply #1 on: July 26, 2011, 06:27:55 PM »
maybe got sucked in from a carb sync tool?? But not sure how that would end up in the oil pan....
'74 CB350F
Offline mrbreeze
  • Not your average
« Reply #2 on: July 26, 2011, 06:30:31 PM »
Can't think of any other cause but like you say........how did it get to the oil pan? You would think it got sucked through the intake and blown out the exhaust.
MEMBER # 257
Offline crackerbat
« Reply #3 on: July 26, 2011, 06:38:15 PM »
I dunno about that.  It wouldn't atomize with the gas, nor does it compress.  It's pretty heavy, it could likely seep and sit on the ring and gradually squirt past on compression?
It would then reform into larger globs in the pan.
Offline mrbreeze
  • Not your average
« Reply #4 on: July 26, 2011, 06:44:55 PM »
Is that your FINAL answer??? :D :D
MEMBER # 257
Offline crackerbat
« Reply #5 on: July 26, 2011, 07:56:03 PM »
Just a possible alternative.  I'd expect it to get sucked thru the exhaust myself.
My final answer would be to stop using an old glass thermometer to check our oil temp  ;D
Offline mrbreeze
  • Not your average
« Reply #6 on: July 26, 2011, 08:43:28 PM »
I've heard alot of people say that they sucked some up when using that type of synch tool. I spent the extra coin a few years back and bought the Morgan carbtune. I find it to be a great investment.
MEMBER # 257
Offline Rgconner
« Reply #7 on: July 26, 2011, 08:53:17 PM »
I thought about a carb tune as well as I whanged on the screws to get the oil pump off...
Sounds as good as any explanation.
Offline Deltarider
« Reply #8 on: July 27, 2011, 05:22:47 AM »
Mercury in a pan? Mercury in a pan?
Could it be the PO was looking for gold?
CB500K2-ED Excel black
"No one is illegal on stolen ground."
Offline Rgconner
« Reply #9 on: July 27, 2011, 06:47:42 AM »
Could be, could be...
This is California Gold Country. American River is a block away and I ride the 49 past the discovery site in Coloma as part of my favorite ride.
