Author Topic: Adding fuel to the oil additive fire........  (Read 1238 times)
KingCustomCycles.com
« on: July 29, 2011, 05:39:17 PM »
I added about a cup of Lucas engine oil stop leak to a recent SOHC 750 rebuild of mine.  The cam pucks were seeping and depositing fresh oil on the lower fins, left side, after the first few runs.  I was NOT looking forward to pulling the motor.  2 short rides and sitting a week and no leaks, none, nada.  Clutch feels normal, oil looks good.  I will run it a few more miles, drain, and add fresh oil.
Offline MoMo
  • Ride like you're invisible
Re: Adding fuel to the oil additive fire........
« Reply #1 on: July 29, 2011, 05:52:00 PM »
Good info, let us know the results...Larry
« Reply #2 on: July 29, 2011, 06:02:04 PM »
Hmmmmmmmm, sounds good.
Offline grasscutter
  • Love the CB650.
« Reply #3 on: July 29, 2011, 07:32:42 PM »
Main base ingredient is paraffin.  (of which Quaker State and Pennzoil use the most).  Its a temp fix.  Fixing the leak, gasket, or seal would be the long term solution.
Come on!  We're burning daylight!
« Reply #4 on: July 30, 2011, 11:06:07 AM »
I would not be so sure about it being a temp fix. When I instruct people on rebuilding air brake pistons, we use Molykote gasket and O ring grease. It tells you right on the label to assemble quickly since it w cause the seals to swell quickly. Many additives cause gaskets to swell. Lucas may be doing the same thing.
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #5 on: July 30, 2011, 11:38:38 AM »
I don't have any argumentative points. Just like to hear about the outcome of the experiment.
1970 CB750 K0
1975 CL/CB 360 Mix
