I have a rechargeable sealed lead acid 12v battery that may fit in the cb750f,, the rating for the battery is 12v 20ah, is this ok to use for the bike, or should I just go with a normal bike battery.
will the higher rating of the 20ah damage wiring
or create any dangerous conditions ??
I can supply more details of the battery if required
It came out of a mobility scooter - they are charged via an external charger that plugs to a 240v 10amp outlet.
thanks for your replies
