Author Topic: Mounting turn signals  (Read 489 times)
Offline jamman718
« on: August 24, 2011, 11:09:16 AM »
Mounted rear turns on 77 750 ss.  Had to do a bit of adapting for the mounts as they are smaller diameter than the signals. (got the wrong ones) I made a sleeve which fits in the signals tight but is a bit loose on the peg.  Have tape to hold for now but I need ideas on something more permanant like a screw to go through sleeve and hit the mount?
Offline jamman718
Re: Mounting turn signals
« Reply #1 on: August 25, 2011, 11:22:32 AM »
Amazing what a little dab of epoxy will do!  Problem solved and I can still remove the lights if needed!
