First Question: I continually am blowing my rear taillight bulb (actually, only the filament for the taillight, not the brakelight). I first checked the ground and made sure it was good, then I mounted a thin rubber washer between my taillight backplate and its mount underneath my seat (custom seat, aftermarket light), but it still keeps blowing out. Am I still getting too much vibration back there, or could there still be an electrical gremlin in the mix? I even made sure the bulb socket was clean. Thoughts??
Second Question: I am replacing my stock rubber front brake hose with braided stainless, and despite my searching of the archived posts, I can't figure out what size I need. Length I have figured out, but nowhere in my manuals does it give the size of the banjo fittings. In catalogs and online, there are listings of 10mm, 12mm, and 3/8". I will rule out the 3/8" because these bikes are Metric, but how do I figure out which size I need? I will be getting new hoses, banjo fittings, and a new bolt to go into the MC/Lever housing. Thoughts?
- Chris
