Author Topic: PD carbs - does this thing come out?  (Read 873 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: August 27, 2011, 12:40:57 PM »
...and if so, does it just press out?
Offline wrenchmuch
Re: PD carbs - does this thing come out?
« Reply #1 on: August 27, 2011, 12:52:08 PM »
It does come out but they are often stuck in with varnish . Its also very soft and is easily distorted . You can leave it in place . Just clean the emulsion tube below it . If you must remove it try pressing it out from above with a piece of wood like a chopstick .
CB750K1
CB750K4
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: August 27, 2011, 12:53:36 PM »
Yeah, that's what I thought but couldn't remember exactly. Think I'll just leave it in place. Thanks!
« Reply #3 on: August 27, 2011, 01:25:47 PM »
you wont get it as clean if you dont pop it out,it has tiny holes along its length you might not get clean just by blowing through it.
Offline hapakev
  • Your Standard
« Reply #4 on: August 27, 2011, 01:34:27 PM »
I think thats the needle seat, it doesnt have holes does it?
Smoking Jack
1978 CB750F(ish)
Offline wrenchmuch
« Reply #5 on: August 27, 2011, 02:21:07 PM »
No . The emulsion tube threads in below it or presses in and has the holes . The piece in the pics is short . About 3/8" long and has a raised collar at the mid point . Unless your replacing the needle and that seat I'd leave it in .
CB750K1
CB750K4
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #6 on: August 27, 2011, 02:46:04 PM »
Yep - pushed one out. No holes.But good to know it's just a seat.
