Author Topic: Could this cause fuel delivery problems?  (Read 1286 times)
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« on: August 30, 2011, 06:37:43 AM »
1976 cb750k. My fuel line dips down quite a bit before reaching the carbs. I am having no problems when the bike gets throttle, but when coasting at low speeds the bike almost feels like it is skipping. Could fuel be having trouble getting to the carbs when there is no throttle? Here is a pic
Offline WarwickE36
Re: Could this cause fuel delivery problems?
« Reply #1 on: August 30, 2011, 06:51:14 AM »
Looks a bit pinched, which could cause fuel starvation.  However, probably isn't the cause for the problem you are troubleshooting.  That being said it should be addressed before you move on with the diagnostics.  Always fix a known problem before moving on to an unknown.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline robdrobd
  • Who? Me?
« Reply #2 on: August 30, 2011, 06:57:46 AM »
It seems like it's going uphill a bit
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: August 30, 2011, 07:00:53 AM »
The kind of curve you need to worry about in a fuel line is an upside-down "U" bend where air can get trapped at the top, not the kind in your picture.  Missing at low speed isn't typically a symptom of a fuel delivery issue.  That problem would show itself at high speed/high rpm when the engine needs more fuel than is being provided.
« Reply #4 on: August 30, 2011, 07:03:38 AM »
750's can run quite awhile even with the petcock off as I am sure we have all found out at least once.Doubt that would cause the issue you are having with the coasting.Starvation would rear its head more at higher revs I would think.     WHOOPS - Looks like Gordon and I are thinking along the same lines  :)
« Last Edit: August 30, 2011, 07:05:12 AM by ekpent »
Offline robdrobd
  • Who? Me?
« Reply #5 on: August 30, 2011, 08:02:52 AM »
Hmmmm. Well thought I would ask before I did anything drastic.
« Reply #6 on: August 30, 2011, 08:16:29 AM »
a clear fuel line might reveal a 'bubble' in the high portion of your fuel line routing.
its a gravity system.  air will always seek the highest point.
just 'burp' your line to expel the bubble.
w/ PC open,  lean your bike in the same direction as the flow of gas.
the fuel line should fill and expel the bubble upwards. more air shouldn't be introduced into they system again unless you remove the line from your carbs or decide to blow into your overflow tubes.  ::)
Offline wanackg
« Reply #7 on: August 30, 2011, 08:43:09 PM »
Only if its kinked or, as previously said, there is an air bubble in the line.
1981 Honda CB650 Custom
#$%* happens. It's what you do when it hits the fan that matters
When my time comes, I want to be buried face down so that anyone who doesn't like me can kiss my ass. -Red Forman
