Author Topic: Spark plug cap ohm question  (Read 1157 times)
Offline Johnny5
    • CB350F build thread
« on: September 12, 2011, 09:38:23 AM »
On my CB750K7, should I have 5ohm plug caps or 10ohm? Im running non-resistor type of spark plugs. I tested the caps that are on the bike now and all but one read in the 9.5ohm range. One read at 11.5ohms, so I replaced that cap with a good one I had laying around. Im going to just replace them all with new ones, but just curious on which I should get, 5 or 10ohm?
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Spark plug cap ohm question
« Reply #1 on: September 12, 2011, 09:40:29 AM »
You sure you don't mean 5K Ohms and 10 Kohms? Big difference.
Offline Johnny5
« Reply #2 on: September 12, 2011, 09:47:40 AM »
Yes, 5 and 10K.
1971 CB350
1973 CB350F
« Reply #3 on: September 12, 2011, 11:21:32 AM »
I think stock on the 750's were 10KOhms, 11 or 9.5 is not that far off. I am not sure what the replacement tolerance is for these caps though. TT would probably have a better idea.
« Reply #4 on: September 12, 2011, 02:32:27 PM »
...hope someone knows...I was wondering the same :-\...
Offline keiths
« Reply #5 on: September 13, 2011, 06:37:33 PM »
I have read that Honda used 5K caps on everything until the mid ninety's. The one's on my CB350F were reading around 12K with one at 52K. It runs much better with the new 5K caps.
« Reply #6 on: September 13, 2011, 07:04:21 PM »
The 550s had 10K from factory.
CB750s were 5K ohm. Possibly there were exceptions.
Offline keiths
« Reply #7 on: September 13, 2011, 07:10:11 PM »
Thanks TT. I guess you can't believe everything you read. Here is where I got mine. http://www.newmotorcycleparts.com/electrical/coil_accessories.html
