Author Topic: Fuel Hose Routing  (Read 5519 times)
Offline WhyNot2
  • I'm finally an
Fuel Hose Routing
« on: September 14, 2011, 02:33:31 PM »
I'm guessing this is not the way the lines are spose to go?
The second pic is the inside of the tank , at the petcock exit hole.
And does it look like I'm missing something?
All help is appreciated.
« Last Edit: September 14, 2011, 02:35:15 PM by budlite282 »
Offline CycleRanger
  • No comment about being an
Re: Fuel Hose Routing
« Reply #1 on: September 14, 2011, 02:53:54 PM »
Looks like the tube and screen are missing from the petcock.
The fuel lines should be routed above the carbs.
« Reply #2 on: September 14, 2011, 03:00:32 PM »
I think Cycle Ranger has it...you want your fuel to never have to go up.  What year bike?  I used to have a k5 tank with a petcock like yours on a k1...the k1 tank had the petcock on the other side of the tank with dual fuel outlets...so it made fuel hose routing awkward, especially when you gotta fit a fuel filter in there somewhere...
Offline WhyNot2
  • I'm finally an
« Reply #3 on: September 14, 2011, 05:22:43 PM »
So, I'm guessing I can reply to my own topic.
CycleRanger, Thanks man, preciate the response.
Sean, Thanks too man.....that may explain....idles sort of ok, ...wants to die when I get on the throttle.
Once again, Thanks guys. Gonna have to stop by Street and Trails here in Augusta and see if they have fuel line in stock.
Looks like a new petcock is in my future too.
« Reply #4 on: September 14, 2011, 06:06:52 PM »
Try to get some polyurethane or Tygon lines. The don;t need clamps and it is bends easier. You have your fuel trying to go uphill. Put the line on the carb inlet first, and experiment with different routings, it will come to up to you. If you are going to use a filter, use one with a 90 degree inlet. It really helps with routing.
Offline WarwickE36
« Reply #5 on: September 14, 2011, 06:15:38 PM »
+1 for tygon
Get a petcock screen, avoid the in line filter
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline CycleRanger
« Reply #6 on: September 14, 2011, 07:15:03 PM »
Here's a shot from my K5. I'm too lazy to pull the tank.  :)
The line goes through the hole in the stay plate.
And yeah, go with the screen in tank.
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #7 on: September 14, 2011, 08:57:28 PM »
Maybe you guys can enlighten me about avoiding the inline filter as well as not having the fuel run "uphill". I've used a setup on my 550 almost identical to that in the picture on my 550 for years (except I have 2 lines/filters), and I haven't had a problem. I actually copied the setup off another 550 I saw parked once- it seemd like a good idea and I do like the added filtration. As long as the tank outlet is higher than the carb bowls- which it always is, the fuel easily flows down and back up the "U" turn and fills the bowls in the usual manner, pushing any air ahead of it out of the vent lines. So what is the rationale behind both not using inline filters and avoiding the uphill part of the run?
« Reply #8 on: September 15, 2011, 02:47:37 PM »
I like fuel filters, I do not believe that fuel like water likes to go uphill. If you had a pump no problem. To get maximum fuel flow you want the line to bend gently if at all and always have it going downhill. The filter adds a bot of restriction, going uphill adds more. When the bike is upright the tank is way above the inlet, on a turn the angle decreases, tight turn even less angle.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #9 on: September 15, 2011, 03:04:46 PM »
If Honda would have wanted fuel filters in the line they would have designed it that way.
Running the fuel line uphill and adding filters adds to ability of air pockets to enter the line and stay there in the elevated sections and restricts fuel flow.
I have seen people do lots of goofy things in my life but I usually never cared to ape their actions unless it was in the name of fun.
Offline CoachDoc
« Reply #10 on: September 15, 2011, 05:54:43 PM »
Interesting comment about the air pockets and "uphill run" restricting flow in the lines. At times I've used clear fuel lines with filters and the lines running down and up as described. Most of the time you can see air in there, but I've never had a problem with restricted flow. Once I  had 2 sticking float jets causing those 2 carbs to spill fuel like crazy out the overflow tubes. You could see the air in the lines, but the fuel flowed around it like Niagara Falls, and this seems to be the case when operating as well. Conclusion might be that while the flow of fuel could be maximized by removing the filters and uphill stretch, but it's not necessary in practicality as plenty of fuel is getting through. Might be a bigger problem on bikes with 1 line feeding all 4 carbs.
Offline Gordon
  • 750K1, 550K2
« Reply #11 on: September 15, 2011, 06:18:37 PM »
+1
This is the easiest way to route the lines if you use in-line filters.  It's how I route them on my current bikes, and have on others, too, and it's never caused me any problems.  The only "issue", if you can call it that, is the small amount of fuel that's left in the downward bend once the tank is empty, but that's extra fuel anyway since that extra length of line wouldn't even be there if it were routed the stock way.
