Author Topic: Front axle diameter...  (Read 1256 times)
Offline camhello
« on: May 12, 2006, 10:29:17 AM »
Does anyone know the diameter of the front axle?  I need to know to get new bearings...
Thanx!
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
Re: Front axle diameter...
« Reply #1 on: May 12, 2006, 10:54:09 AM »
What bike? I am buying new fronts later today for my 74 550K. I'll post the bearing #.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline camhello
« Reply #2 on: May 12, 2006, 10:54:51 AM »
oops...forgot that part...
it's for a cb750k
thanx!
Offline Dennis
« Reply #3 on: May 12, 2006, 01:45:41 PM »
I think those bearing numbers can be pretty easily determined from some mail order catalogs like Dennis Kirk, JCW or Chaparral.
I assume that you are buying from a local bearing house, thats OK.
If you get the bearing number, you won't need to know that axle diameter, or you can determine it easily if you need to.
Just curious, how will the axle diameter help you without the OD and width of the bearing?
Offline puppytrax
« Reply #4 on: May 12, 2006, 02:04:14 PM »
Maybe he's making a trailer hitch towing adapter...I been thinking of that myself...but I don't think I need bearings...just a hole through my receiver...
Anyone ever try that??? I've seen the semi-ramp ones on the Web...too expensive...
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline clarkjh
  • Expert? If only.
« Reply #5 on: May 12, 2006, 03:53:52 PM »
Just put the new ones in my front hub, Koyo 63092-2RS.  The old ones where 63092-RS, the only difference is my new ones are 2 shield (dust cap on both sides) instead of single shield (dust cap on one side).  I don't know if its the same for the 750 but I think it is, I just took the number off the old bearing, and Bobs your uncle. ;D
James
SOHC/4 #3328
