Author Topic: '78 GL1000 Front on '74 CB750  (Read 639 times)
Offline jabs83
« on: October 14, 2011, 04:48:46 PM »
I'd like to do a front end swap on my '74 cb750k, and I have the opportunity to scoop the front off of a '78 GL1000.
First - with these two model bikes, it should be a straight swap not needing any frame or steering head mods - correct?
Second - with the added addition of stopping ability, are will there be any other differences in steering performance versus the stock cb front end?
Thanks in advance for input.
Re: '78 GL1000 Front on '74 CB750
« Reply #1 on: October 14, 2011, 06:16:36 PM »
...gl forks have 38mm(or 37?) tubes versus cb 35mm, a little more rigid...throw on a fork brace from Randakk's (ohh, but it's pricey...anybody found any others?) and you should have decent rigidity...
Offline Ricky_Racer
« Reply #2 on: October 14, 2011, 06:48:14 PM »
More knowledgeable members are welcome to correct me, but I believe you'll have to use the '75-'76 triples with your forks (37mm tubes) to easily mount the front end to you K4. The steering bearings are the same for your bike and for the earlier GW.  RR
