Author Topic: Air mixture screw..  (Read 1621 times)
Offline surein
Air mixture screw..
« on: October 14, 2011, 04:41:30 PM »
hey so I'm trying to follow the manual and it says one full turn - is that a full turn loose from the screw tightened all the way till the spring compressors? Please say no cause that's what I have it and the bike idles at 5000rpms. Just want to know there's nothing significantly wrong with my bike.
It ran well with 3 turns from full tightened but I think it's a bit rich cause I get a little bit of back firing when I blip and throttle to a lower gear.
so I have this backwards?
It's a 73 CB750
Thanks
« Last Edit: October 14, 2011, 04:45:31 PM by surein »
Offline CycleRanger
  • No comment about being an
Re: Air mixture screw..
« Reply #1 on: October 14, 2011, 05:34:20 PM »
Seat the screws lightly all the way in.
Back them out one full turn as a starting point and adjust from there.
The further out the screw the leaner the mix.
See this thread: http://forums.sohc4.net/index.php?topic=5410.0
Have you done a carb sync?  If not you may not be able to get it to idle smoothly.
Offline Fritz
« Reply #2 on: October 14, 2011, 05:41:45 PM »
Could you confirm that you really know the difference between "idle screw" and "air mixture screw"?
There are four air mixture screws (one in each carb) which have to be adjusted one after another on a warmed up motor until you get the highest idle.
The idle screw is used afterwards to adjust the idle speed back to about 1100 rpm.
Reading your post, I've got the impression that you mixed up idle and air mixture screw...
Cheers
Fritz
1976 CB550F
Offline surein
« Reply #3 on: October 14, 2011, 06:44:19 PM »
frak! there's more than one screw? I need to read this book again
Offline Johnie
« Reply #4 on: October 15, 2011, 06:56:01 AM »
This should help you out. My pinky is pointing to the idle adjustment screw of which there is one which adjusts the idle on all 4 carbs with that one screw. My index finger is pointing to the air mixture screw of which there is one on each carb. The other small screw you see between the two is the sync port for your vacuum gauges if you want to sync the carbs. Click the pic to enlarge it.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
