Author Topic: Timing or.....?  (Read 969 times)
Offline John Galt
Timing or.....?
« on: October 23, 2011, 01:54:11 PM »
Hey. My cb550 is getting spark to all cylinders. 1 cylinder is cold, 2 is warm, 3 and 4 are hot.  Anybody point me in the correct direction? And how warm should the rectifier be? Thanks.
Live free or die.
Offline WarwickE36
Re: Timing or.....?
« Reply #1 on: October 23, 2011, 02:01:05 PM »
Time to pull the carbs and thoroughly clean them ... sounds like idle jets /passages are clogged.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline Danno
  • 74 CB550,75 GL1000,76 KZ400,77 GL1000,73 CB750
Re: Timing or.....?
« Reply #2 on: October 23, 2011, 09:10:31 PM »
he is right and check the fuel level in the bowl and the float level and also make sure the floats are not binding and are free to move up and down and how are the plugs are the ones that are cold or not getting hot white ?
when you own a motorcycle the wife does not have to find you handy she just has to find you
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
Re: Timing or.....?
« Reply #3 on: October 24, 2011, 06:06:04 PM »
That's GoldieLock's syndrome, The bike will eventually settle for #2 or #3 as it's sweetspot for running..... :P
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline Patrick
Re: Timing or.....?
« Reply #4 on: October 24, 2011, 06:12:58 PM »
Check to make sure your fuel line is not kinked or plugged. Are you running inline filters? If so, if you run a fuel filter horizontally it can trap air and cause a vapor lock.
Just two wild guesses, but both are easy to check without pulling the carbs.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
