The SOHC/4 World Tour is in under way.
I hadn't considered the difference in the width of the swing arm, either. The off-set front sprocket is the easiest, least expensive way to go. With your mostly stock motor, the primary shaft bearings shouldn't be a problem.
Quote from: ekpent on November 06, 2011, 07:18:18 PMDoes the bike still have the 17 inch rear tire which I think is 77-78 or the earlier 69-76 18 inch rear? If it has the 17 then I would stick with the 18/48 combo.Has the stock 17" rear tire.
