Author Topic: carbs 2/3 vented into airbox is it correct- cb750-1971  (Read 1807 times)
Offline alabama1971
  • 1971 cb750 custom chopped
« on: November 17, 2011, 06:50:35 PM »
Removed carbs for cleaning and 2/3 are vented into the airbox filter assembly, two small holes drilled in housing and tubing stuck thru about two inches please advise if this okay?
Thanks Ken
Offline CrankyOldGuy
  • Wish I was a
Re: carbs 2/3 vented into airbox is it correct- cb750-1971
« Reply #1 on: November 17, 2011, 06:59:56 PM »
Alabama,
I do not see this on my 750K1.
Harry
750 K1 Original Owner
Offline Roach Carver
« Reply #2 on: November 17, 2011, 07:16:53 PM »
I just read in the hondaman book that yhis enrichens the carbs? Dont know why you would just do the two in the middle though. Weird. Anyway not normal as far as I know
Offline alabama1971
« Reply #3 on: November 17, 2011, 07:20:13 PM »
Thanks Harry we couldnt be much farther away as you are about as far North as I am South, Im all the way to the Gulf of Mexico!
Im jealous as I hear your area is a beauty up there and probably a really great place to spin the tires!
Take care
Offline alabama1971
« Reply #4 on: November 17, 2011, 07:24:13 PM »
Thanks Roach/Harry- how and where should they be vented to, I cant really find a closeup picture anywhere with details, im in South Alabama and dont know any fellow 750 -4 bikers around to compare motors with
Ken
« Reply #5 on: November 17, 2011, 07:26:37 PM »
Theres a plate on the back of the engine they route thru. Essentialy they route to the ground.
DH
« Reply #6 on: November 17, 2011, 08:45:01 PM »
If its like a later k series, the two tubes "arc" up and over top of the air cleaner housing. The hoses sort of lay on top of the airbox and lead to no particular port, etc., they just go to the atmosphere. A small plastic clip neatly pairs the hoses together. The carb float chambers vent thru these hoses.
Carbs 3/4 are connected and vent thru one hose, and carbs 1/2 are connected and vent thru the other.
P.S. these are not to be confused with the 4 lower overflow tubes
connected to the bottom of each float bowl.
« Last Edit: November 17, 2011, 09:00:08 PM by DH »
« Reply #7 on: November 18, 2011, 03:48:26 AM »
its not. Diff carbs on a 71.
Offline Doum
« Reply #8 on: November 18, 2011, 04:40:31 AM »
Drop it to the ground,I have ever done the same on a atv,and this should cause problem.The vacuum in the airbox cause overflow and rich burning at high rpm
« Reply #9 on: November 18, 2011, 07:02:29 AM »
  • Wish I was a
« Reply #10 on: November 18, 2011, 05:18:21 PM »
Alabama,
The world is small.  I spent almost all of year (00/01) in our Chattanooga office working on a thermal plant in northern Alabama.  It was beautiful country.  Just had a touch of snow last night but it suppose to go to 50F tomorrow.  Motorcycle season is over  for "most" people up here until late March/early April.  Then again I have been seen early in my life on the road in early February; all you need is a snowmobile suit, a good set of gloves and no ice.  Hmmm .. I wonder what the windchill factor is at 0F doing 80 mph  ::)
Harry
Harry
