Author Topic: CB350F - is there supposed to be a bolt here?  (Read 3220 times)
Offline ADW
« on: November 24, 2011, 05:47:09 AM »
Hi there. Have begun disassembling my new-to-me '72 CB350F. I noticed what appeared to be a bolt hole in the cases without a bolt in it. See the photo; the photo is of the cases below where 3 & 4 exhaust outlets are, right below the 347CC stamping. Is there supposed to be a bolt in there? Do you other 350F owners have one? I can't see any obvious witness marks that were left by a previous bolt, so maybe it's just an alignment hole that was used on the assembly line to guide the cases together or something. Also it is a complete through-hole, i.e. the lower case isn't threaded. Both cases just have an unthreaded hole of the same diameter.
Can other CB350F owners reply and let me know if they have a bolt in that position? Thanks!
Offline Rigid
  • She likes a
    • KingCustomCycles
Re: CB350F - is there supposed to be a bolt here?
« Reply #1 on: November 24, 2011, 06:05:02 AM »
No bolt, same as a 750.
Offline graeme7
« Reply #2 on: November 24, 2011, 06:06:48 AM »
So what is it?
Ive wondered the same thing.
Its very near the clutch cable routing, i did wonder if the cable was ment to go through that but though that would be odd considering the heat!.
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #3 on: November 24, 2011, 06:11:49 AM »
I am guessing it might have been a tooling attach point during engine assy at the factory.  Someone knows this kind of trivia here..........
Offline ADW
« Reply #4 on: November 24, 2011, 07:11:53 AM »
Offline camelman
  • Man... Myth... Legend
« Reply #5 on: November 24, 2011, 08:58:08 AM »
Oh man, that's where I attach my decelerator pump.  Didn't your bike come with a decelerator pump?  I wouldn't put that thing on the road without one!
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
« Reply #6 on: November 24, 2011, 09:14:36 AM »
Camelman
I thought that was for the harmonic exhaust balancer,very crucial and just used on the 350.
« Reply #7 on: November 24, 2011, 09:57:19 AM »
I bolt superchargers in those holes, good, sturdy mounting spot!  ;D
They are locating holes for the CNC fixtures that were used for machining the cases.
Offline Trav-i
  • Has finally become an
« Reply #8 on: November 24, 2011, 10:32:42 AM »
That's where I mounted my super cool ram air pod filter! ;D
Forum member #9962
1992 GL1500 Interstate
