Hi all
I have a 1978 supersport. I worked on this bike last year and it was running fine (opened up and cleaned the carbs, did the valve adjustments etc). I let it sit for a few months. Recently, I have tried starting it and its not starting. Here is what I have tried:
-battery is fully charged
-Fuel is going from tank to carbs
-There is a spark in the spark plugs
When I try the electronic start button, nothing whatsoever happens. When I do the kick start, the engine doesnt seem to roll except for a couple of times.
I am a total novice/green mechanic as you can probably tell from the post. Is there any guidance you can give me on what I should look at next? Ignition coils? points? And how to go about it...? I have the Clymer Honda manual but there is not much that I can tell about debugging coils etc in there. ...
Any help much appreciated!
