Author Topic: A little help please! w/vid  (Read 2474 times)
Offline johnsy
    • what I do!
« on: January 07, 2012, 01:03:03 AM »
So i finally got around to working on my bike 78 550k and im not burning 1 and 2. ive got spark and the plugs are wet but no burn. any suggestions. you can see me touching 1&2 but nothing. 3&4 are good
heres a vid.
thanks
IMG_3598.MOV
current project, cb550 four
75 360T
Offline wedoo2
Re: A little help please! w/vid
« Reply #1 on: January 07, 2012, 02:51:10 AM »
Could the valve timing be off?
Some days the sun is too loud.
Offline johnsy
    • what I do!
« Reply #2 on: January 07, 2012, 11:57:17 AM »
thanks, ill give it a check.
75 360T
Offline scunny
  • don't call me expert
« Reply #3 on: January 07, 2012, 12:04:53 PM »
you haven't swapped the spark leads on 1 & 2 ?
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline lucky
« Reply #4 on: January 07, 2012, 03:30:05 PM »
Forget valve timing.
Do you have a timing light?
Offline lucky
« Reply #5 on: January 07, 2012, 03:32:25 PM »
Give us some back ground info.
Did you adjust the points?
Do you know how?
If the points are used you will not be able to
 adjust them with out a dwell meter.
Are the condensers old or new?
There are other possibilities.
Offline johnsy
    • what I do!
« Reply #6 on: January 07, 2012, 04:02:13 PM »
Do you know how?
dont have a timing light. can get one though.condencers are new, checked them for holding charge. im getting spark on both points this is the second bike ive done points adjustment on so im hoping its my newb points knowledge that its an oversite on 1&2 im going to go back into and adjust them again.
thanks for the info.
75 360T
Offline johnsy
    • what I do!
« Reply #7 on: January 07, 2012, 04:02:56 PM »
no i have not.
75 360T
« Reply #8 on: January 07, 2012, 06:09:21 PM »
just keeping things straight here...one coil, condenser, and points set fires 1 and 4, the other coil, condenser and points set fires 2 and 3
Offline JimM68
    • Firstgens.com
« Reply #9 on: January 08, 2012, 05:42:32 AM »
YES, what he said. If 3 & 4 are running, you have spark from both coils. I suppose you could swap wires between 1 and 4 (or 2 & 3) but that's a long shot.
The carbs are fed paired 1 & 2 and 3 & 4....
If you loosen the bowl drain screw on carb one does fuel drip out?
Thinking a clogged fuel filter, pinched fuel line, or petcock problem for the fuel feed for 1 & 2.
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming 'WOW What a Ride!'"
Offline lucky
« Reply #10 on: January 08, 2012, 12:23:40 PM »
Some confusion here.
One coil fires cylinders 2&3
The other coil fires cylinders 1&4
You can use either wire from 2&3 to go to those two cylinders.
They both fire at the same time.
Same goes for cylinders 1&4, 1 &4 fire at the same time.
If you adjust the points gap and you cannot get the dwell in specs you have to buy new points. You cannot use a thickness gauge on a used set of points. Only on a new set of points unless the used set of points have NO PITTING.
The dwell is the amount of time(rotation of the crankshaft), before the charge the condensers are storing up is released to the spark plug.
Below is a drawing showing WHY you cannot use a thickness gauge on pitted old points. The points gap and DWELL must be in specification at the same time or the spark will be weak or no spark.
« Last Edit: January 08, 2012, 12:35:54 PM by lucky »
« Reply #11 on: January 08, 2012, 04:13:52 PM »
Generally speaking, you can dress up pitted points with a point file. An ancient and archaic instrument, but they did exist. Without one, simply use some emery paper. Hit it with some points cleaner and you're good to go. We did it all the time.
Sure it won't be a primo tuneup, but even pitted points and out of spec gap shouldn't keep you from getting it started on all 4. In my opinion.
As stated by others, the points are paired 1-4 and 2-3. If its 1-2 that aren't firing, I'd have to suspect something else. (carbs)
Though it'll be good to get the ignition as close as possible.
Offline johnsy
    • what I do!
« Reply #12 on: January 08, 2012, 04:28:03 PM »
so basically if I do this wire swap with say 2&3 and 2 then fires its an old points issue, would that be the correct assumption?
75 360T
Offline Killer Canary
  • Typical Bran Muffin
« Reply #13 on: January 08, 2012, 04:43:38 PM »
What they're saying is that if you're getting fire on 3&4, points and coils aren't the problem with 1&2.
Kawi GPz900, H1
Offline johnsy
    • what I do!
« Reply #14 on: January 08, 2012, 05:05:35 PM »
ahh got it.
75 360T
« Reply #15 on: January 08, 2012, 05:14:38 PM »
ahh got it.
Right. If its an ignition problem, whatever is wrong with 1, would show in 4, not 2.   Whatever is wrong with 2 should present in 3.
And old points can cause a poor running condition, occasional misfire, rough idle, etc. Something that you would want to fix. But rarely do old points by themselves cause no fire. Though it is possible, I suppose.
