Author Topic: need help..on 76 550?s  (Read 2356 times)
Offline messeduptriple
Re: need help..on 76 550?s
« Reply #25 on: January 11, 2012, 12:56:00 PM »
I was told it is an o ring chain. Why won't it work???
Also I was going for off red look. Powder coat swingarm red, tank, and was gonna do wheels but heard that might not be the best idea. Pressure from the nipples can crack the paint. This is what I was told so don't quote me on it.
« Last Edit: January 11, 2012, 12:58:56 PM by messeduptriple »
« Reply #26 on: January 11, 2012, 02:01:00 PM »
Grinds into seal due to extra width of chain. Pic below was saved in time before oil starts to squirt out.
« Reply #27 on: January 11, 2012, 02:12:27 PM »
What size chain works then??
« Reply #28 on: January 11, 2012, 02:26:07 PM »
530 or DID50 standard chain.  If you are using the stock sprockets (17F, 37R) then you need 100 links.
« Reply #29 on: January 11, 2012, 05:49:35 PM »
thanks...ordered a gold chain, couldnt get the colored red anymore withouth the o ring. makes me upset...need to change my color theme ...not sure what would balance well with gold chain ...black is overdone i feel. my tank is still in mint vintage green color....hmmmm??
Offline Danno
« Reply #30 on: January 11, 2012, 11:38:00 PM »
I was trying to be diplomatic after I got all upset at that chopper person the other day
and to answer your question the way it runs and the color of your plugs will tell you white is too lean and black is too ritch
