Author Topic: Air Fork Conversion for 80' CB750K?  (Read 2769 times)
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« on: May 24, 2006, 08:40:46 PM »
              I'm putting a sidecar on an 80'CB750K and need to know if it would help the bike to convert
      the forks to air assist? I've seen the tread over on the tech forum but, didn't want to rattle
      anybody's cage by throwing my DOHC into that area. Besides, not only am I asking about
      converting my forks to air, I'm also questioning if it would help the handling of the sidecar? Any
      input from anybody would be greatly appreciated.
                                                              Later on, Bill
     I'd of sworn that I put this on "other bikes" because it is a DOHC.
« Last Edit: May 24, 2006, 09:56:09 PM by bill440cars »
Member # 1969
Re: Air Fork Conversion for 80' CB750K?
« Reply #1 on: May 24, 2006, 10:14:36 PM »
Billy, most outfits I have seen tend to convert to leading link forks.
Sam.
Offline bill440cars
« Reply #2 on: May 25, 2006, 04:38:28 AM »
                 Sam,  I know the type you are talking about (like the old 50's BMWs) but. I've never seen
          any for a Honda. So, I can only imagine that they would be quite expensive and I'm operating
          on a pretty tight budget here. I just thought that, with the extra weight, maybe if I could
          shoot a little air to the front and tighten up the rear, it would help it out. I appreciate the
          response though. Take care Sam and I'll catch you later on.   Bill
Member # 1969
Offline cb650
« Reply #3 on: May 25, 2006, 03:10:22 PM »
The 81 custom 650 had air assist forks stock.  I would think the 750s did to. 650 custom also went with dual disks. Would help in slowing the xtra #'s.  Remember the triple tree is diff with the dual disk.
Hows the project going?
                          Terry
Offline bill440cars
« Reply #4 on: May 25, 2006, 06:46:59 PM »
                          Terry
                  I have heard of people just adding the air valve and suchbut, I got to wondering if
           there were fork seals that would be better or if it would be necessary to change seals I
           don't figure you'd run too much pressure anyway. I'll have to do some checking on the
           CB650 and 750s for the setup
                  As far as the dual discs go, I'm thinking of trying it on the 750 1st (for the sidecar)
           and it seems to be similar to the CB650 setup.
                  I haven't been able to do anything else for now. I've got to get the 750 finished and
           hooked up to the sidecar before I can do much of anything else. I need to finish this
           750/sidecar to transport Jame's in style and to take some of the load off of my pocketbook
          (from filling up that Van). When that project is finished, then I can get back to the 77'
          CB550K project w/ the Comstar wheels. Take care of yourself and I'll catch you later.
                                                            Bill
Member # 1969
Offline 6adan
« Reply #5 on: May 25, 2006, 08:48:12 PM »
I have an 81 CB750K that has air forks,you might try these.They have one valve with a tube between. Dannie
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline cb650
« Reply #6 on: May 26, 2006, 04:29:47 AM »
The max psi was 12 I believe.   I have most of the parts for the 650 setup if you want to go that way.
          Terry
Offline bill440cars
« Reply #7 on: May 26, 2006, 09:21:41 AM »
               Dannie, thanks for the info, definitely appreciate it.
               Hey terry, thanks for the info and the offer, I may take you up on the parts. I do appreciate
       it and I'll get back to you, okay?
               dgfischer, Interesting about sidecar info in your Clymer GoldWing manual. It's too bad the
       750 verseion doesn't have it also. I have several sources of info with setup instructions but, any
       info, that anyone wants to offer, is appreciated.
                                                        Thanks again guys,
        Bill
Member # 1969
