Author Topic: 1980 cb750 rear light, turn signals wiring issue  (Read 3795 times)
Offline bobth1019
« on: January 19, 2012, 09:51:32 AM »
Where to start...
I'm having electrical problems as in lights, turn signals, brake lights..
1980 cb750c. Bought it in good shape, starts, runs. But the guy had decided to redo the stock rear light, turn signals in favor of cafe-style lights but hadn't finished wiring them up just made some changes I can't figure out.
Headlight shell was apart so might have messed with that as well. When I got it in the rear lights were off, the harness / electrical plugs seemed intact and only trace of his work (besides lights not working) was an extra green wire soldered off one of the 2 brown wires at the back that lead to the tail light.
I plugged the old tailight, turn signal housing back in and the two lights in the taillight housing work. Brake light does not flash when brake is applied. Steady lights both bulbs.
Turn signals: front ones...left works but on steady. Right one off. When I flip the turn signal switch the left will stay on when left or in the middle. Goes off when turned to right. But right one does not go on.
Rear ones: neither is on and neither go on when switch is turned in either direction. However if I touch the extra wire that I mentioned that is soldered to one of the brown ones leading to the tail lights to either of the turn signal wires (black with orange or light blue band) the light will light.
From the schematic I have all the wires correctly attached to the correct connectors. I cleaned all of the connectors and battery is charged. Fuses all good.
Front headlight works fine, reg and hi-beam.
I don't know where to start with this...again, all the wires seem plugged into the right connectors and no breaks and grounds seem ok.
Suggestions on where to go with this? I've looked around but not much experience with electrical issues.
Thanks
1980 cb750c
bollingball
Re: 1980 cb750 rear light, turn signals wiring issue
« Reply #1 on: January 19, 2012, 10:42:44 AM »
DOHC Don't know if the wiring is the same as our SOHC bikes? Do you have a service manual with the print?
                                             Ken
« Last Edit: January 19, 2012, 10:44:17 AM by bollingball »
Offline Bido
« Reply #2 on: January 19, 2012, 12:29:49 PM »
Check out the Custom Forum all the info you need will be there somewhere.
[url=http://www.cb750c.com
Bido
1978 CB750 Supersport F3
1981 CB750 K
