SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
adjust the cam chain tensioner?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: adjust the cam chain tensioner? (Read 1794 times)
dgilling
Hot Shot
on:
May 25, 2006, 06:42:51 PM »
how do you adjust the cam chain tensioner? I know the adjustment is right under the carbs and I'm pretty sure i understand it but I want to make sure.
Logged
750k7 Rebuild
http://forums.sohc4.net/index.php?topic=137018.0
Daves_76_SS
Guest
Re: adjust the cam chain tensioner?
Reply #1 on:
May 25, 2006, 08:19:26 PM »
Pull up # 1 cylinder to top dead center then Loosen the nut and screw. Then retighten them and you should be good to go!
Logged
dgilling
Hot Shot
Reply #2 on:
May 25, 2006, 10:38:09 PM »
I found it in a Cleymer manual and it said to put it at 15 degrees befor #1TDC is that right?
Logged
750k7 Rebuild
Daves_76_SS
Guest
Reply #3 on:
May 26, 2006, 04:32:17 AM »
I didn't when I did mine, however if it says you should then I would go by that.
Logged
dpen
Hot Shot
Reply #4 on:
May 26, 2006, 05:36:15 AM »
Check the FAQs or go back through the posts - there have been heaps on this topic
Logged
my78k
I am Meat-O of the Hungry Horses MC
Old Timer
Reply #5 on:
May 26, 2006, 06:44:04 AM »
Definitely check the FAQ's and if you don't have any luck re-post but include the model and year as different SOHC's have different adjusting procedures (or atleast that is what I have read in previous posts).
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
