Author Topic: Tip of air/idle screw broke off in hole...77 750F  (Read 3519 times)
Offline Lumbee
    • My pics...
« on: May 26, 2006, 08:44:21 AM »
...so now its blocked.  I know that cylinder is gonna run rich, but whats you guys opinion on how long I can run it this way.  For a season, then worry aobut it in the fall, or do you think I'll foul a plug before then?
« Last Edit: May 26, 2006, 09:08:02 AM by The great "Lumbee" »
"I'm not a welder, but I play one on HondaChopper.com"
Offline crazypj
  • I'm brill, me
Re: Tip of air/idle screw broke off in hole...
« Reply #1 on: May 26, 2006, 08:55:35 AM »
Its going to run lean with the tip stuck in the hole. You should be able to push it out after you take the carbs off.
PJ
Offline Lumbee
    • My pics...
Re: Tip of air/idle screw broke off in hole...77 750F
« Reply #2 on: May 26, 2006, 09:07:44 AM »
FYI is a 77 750F...i thought turning the screw in removes the air therefore richening the mixture.
« Reply #3 on: May 26, 2006, 09:50:50 AM »
The 77 and 78 carbs have an Idle Mixture Screw.  It adjusts the fuel/air mix coming from the slow circuit (air and slow jets) in total.  If the mixture screw was over tightened and broke off at the exit hole, no fuel air mix is going to make it into the carb throat, and the engine will run lean.  I don't think it will idle on the that cylinder either, because the idle/slow circuit is now shut off entirely.
Go ahead and run it.  If you like the SOHC3 sound and performance at idle, and a crispy single spark plug.
Offline scondon
  • Mmmm......tasty bugs
« Reply #4 on: May 26, 2006, 10:09:06 AM »
    TT's right. The screw meters fuel, screwing it in makes it leaner, all the way in shuts it off. If the needle tip is in the hole and you back the screw out then you may get fuel to flow, but with the tip just "floating" around I imagine that it would run pretty inconsistently.
   Just looked on Powersportspro(expensive) and see the screw,spring,washer,o-ring listed at $11.64. If Honda still sells the part it would be worth your peace of mind.
Offline Lumbee
    • My pics...
« Reply #5 on: May 26, 2006, 10:46:41 AM »
...hmm...so does in the IN=Lean Out=Rich apply to the 69-76 models also?
Offline scondon
« Reply #6 on: May 26, 2006, 10:55:40 AM »
No. For earlier carbs the reverse is true. It's been said here before, but to repeat, mixture screws on the air intake side of carbs regulate the amount of air(fuel is constant). Screws on the engine side of carbs(like yours) regulate amount of fuel(air is constant).
Offline Lumbee
    • My pics...
« Reply #7 on: May 26, 2006, 11:01:44 AM »
..ahh (the clouds just parted I think).  So on the earlier carbs, the screw is on the airbox side (don't have any exp. with earlier carbs).  Makes sence...
...yea, the bugger broke off in there, and its gonna have to be drilled out, I sewing needle is the only thing I could find small enought, and it breaks when I try to push it out the other side.  Gonna have to find a drill bit small enough to drill it out...
« Reply #8 on: May 26, 2006, 11:45:05 AM »
Well, that's a metered orifice.  The more buggared that finely tappered hole becomes, the more unlikely it can remain a controlable metering mechanism.  Better start shopping for another carb body if you can't drive it out cleanly.
Good luck!
Offline Lumbee
    • My pics...
« Reply #9 on: May 26, 2006, 11:49:25 AM »
...yea, thats why I'll need to drive it out from the smallest end, that way it was hose the taper up...
Offline dusterdude
« Reply #10 on: May 26, 2006, 01:49:43 PM »
good god,you go to mytle beach for a week and come back all screwed up. ;D
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline 6adan
« Reply #11 on: May 26, 2006, 07:32:01 PM »
If you find a way to get that little tip out please let me know I have the same problem on a 81 750K. Thanks Dannie
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline jtb
  • An unlikely
« Reply #12 on: May 29, 2006, 05:38:45 PM »
Lumbee, which carb?  I may have an extra body with the idle screw.
John
1977 CB750F
1985 V65 Sabre
Offline Lumbee
    • My pics...
« Reply #13 on: May 29, 2006, 06:12:22 PM »
#2 carb with Accel pump/choke spring...lemmie know what ya got...
Offline jtb
  • An unlikely
« Reply #14 on: May 30, 2006, 05:52:20 AM »
Got the #2 body.  Do you need the bowl, slider and other stuff?  I can probably dig that up too.
1977 CB750F
1985 V65 Sabre
Offline Lumbee
    • My pics...
« Reply #15 on: May 30, 2006, 05:55:26 AM »
...u da man JTB...u'v got PM...
