Author Topic: 73 CB500 4 "Free" Style  (Read 22341 times)
Offline XC204
Re: 73 CB500 4 "Free" Style
« Reply #75 on: March 28, 2020, 10:44:28 AM »
Got a few things accomplished today brake mounted and hosed and working on the battery box mounting.
Offline XC204
« Reply #76 on: March 29, 2020, 11:44:52 AM »
Got the brackets for the battery box finalized. The solenoid will mount to the left of the battery. I ordered a mount for it yesterday (got lazy and didn't make it) from this user parts place in Ann arbor .
Offline XC204
« Reply #77 on: April 09, 2020, 01:02:59 PM »
Got the battery box powder coating done and mounted the solenoid and battery box.
Gary
Offline XC204
« Reply #78 on: April 11, 2020, 05:45:29 AM »
I found some more photos on some of the parts refurbished and the electrics box and my home built powder coating oven.some have been done for a while but I hadn't been posting then.
Gary
« Last Edit: April 11, 2020, 05:49:58 AM by XC204 »
Offline XC204
« Reply #79 on: April 24, 2020, 03:56:58 PM »
Started on the carbs nothing moved, floats stuck had t get an ultrasonic cleaner. Got everything apart but the floats they are really stuck. I ordered carb kits and floats because I'm going to have to cut them out so I don't break the towers. Simple green really cleaned them up. Going to powder coat caps and bowls and soda blast bodys. Also have one main jet tower to fix. I think that I have watched Classic Octane cb500 carb rebuild video about 3 times to get up the guts to do the rebuild. Thanks Taylor!
« Last Edit: May 14, 2020, 05:59:42 AM by XC204 »
Offline richmagee7
« Reply #80 on: April 26, 2020, 08:54:11 PM »
I'm eight years late to the party but, subscribed.  Like that powdercoating you're doing yourself.
Offline XC204
« Reply #81 on: April 27, 2020, 05:27:09 PM »
Rich I'm the one who is 8 years late! Life got into the way for me till last winter. Thanks I enjoy the powder coating and got a pretty good gun from Columbia Coatings real nice to work with even though I'm just a hobbyist. I got the carbs all cleaned up then soda blasted them. I powder coated the caps and bowls and repaired the main jet towers. I lost one of the felt washers on the slide shafts so O ring of make one?
Gary
« Last Edit: April 27, 2020, 05:46:15 PM by XC204 »
« Reply #82 on: April 28, 2020, 02:58:51 AM »
McMaster Carr is a good source for the industrial felt needed for the washers.
Offline XC204
« Reply #83 on: May 03, 2020, 06:56:43 PM »
All put together just need to do a bench sync. I'm going to buy some stock air box boots and make my own air cleaner something like this photo. Oh and dang a carb set is heavy! Oh and a question the tubes that connect 1&2 and 3&4 and go off of 2&3 where do they go and what is there function , a vent to air?
« Last Edit: May 03, 2020, 07:02:19 PM by XC204 »
Offline XC204
« Reply #84 on: June 12, 2020, 08:59:20 AM »
Made the shock bolt mount plate holder last week got it powder coated and mounted this morning.
Gary
Offline XC204
« Reply #85 on: July 03, 2020, 05:43:32 AM »
Been kind of busy at work so haven't gotten much done. I did get slight holder for the license plate holder done and mounted and modified a harbor freight chain tool to rivite my cam chain link and put the chain back on. For the tool I sharpened the extra pin and group down an alien head bolt that just fit in the open end of the tool for a backer for the other side of the link so as not to push the pin out when upsetting the loose link side. Boy that tool is a crude casting.
Gary
« Last Edit: July 03, 2020, 06:29:03 AM by XC204 »
Offline XC204
« Reply #86 on: July 04, 2020, 07:08:08 PM »
After a few hiccups with upside down oil jets not letting cylinders go all the way down got some help from Bondi and got this far today.
Offline XC204
« Reply #87 on: July 22, 2020, 03:56:39 AM »
Got this far with a  little help from my friends here waiting on tappet screws and Talley cover I rings .
« Reply #88 on: July 22, 2020, 03:03:08 PM »
Don't forget to rubber band the rocker arms up when putting the cover back on... don't want to bend things...
Offline XC204
« Reply #89 on: July 22, 2020, 07:49:56 PM »
RAF yes I've got a handful to use for this thanks to reading posts on the site. I'm waiting on tappet screws now before putting the cover on.
Thanks
Gary
Offline XC204
« Reply #90 on: August 01, 2020, 05:29:57 AM »
Got my tappet screws in and the new cover gasket from David Silver Spares it only took 4 days I think. The top gasket is from DSS and the bottom one Crusin Image it wouldn't stay in the groove and was slightly long too. I now have about $100 in 8 screws and a gasket!!!! Dang
Gary
« Last Edit: August 09, 2020, 04:44:06 AM by XC204 »
Offline XC204
« Reply #91 on: August 07, 2020, 05:01:02 AM »
Got the valve cover on (with the rubber band method) and started adjusting the valves only had a.004 feeler gauge which I broke bending to fit so I'm waiting far a correct gauge from dime city also some cu washers for end cap clamp and the 6 cover bolts that call for them. I also built a tappet and wrench out of a socket and 1\4-20 bolt.
Gary
« Last Edit: August 09, 2020, 04:44:57 AM by XC204 »
Offline bahia
    • William Bay
« Reply #92 on: August 07, 2020, 12:41:54 PM »
Ahhhh, yes. This is a lovely build indeed!
I will be keeping an eye on this for sure!
"Bruce" - CB500K2 + 197? 550 forks + Honda tank(maybe)
Offline XC204
« Reply #93 on: August 09, 2020, 08:52:25 PM »
Got the valves adjusted and top end buttoned up.
Gary
Offline grcamna2
« Reply #94 on: August 09, 2020, 09:47:23 PM »
subscribed
75' CB400F/'bunch o' parts'
Offline XC204
« Reply #95 on: August 22, 2020, 11:10:31 PM »
Got oil pressure gauge parts in and installed still need to clamp it or the case and maybe shorten the tube.
Gary
Offline XC204
« Reply #96 on: September 06, 2020, 07:11:45 PM »
Yea I have oil pressure! Took a few ten second cranks now comes right up each time. Pretty soon going to have to take it out of the basement to the garage.
Gary
Offline XC204
« Reply #97 on: September 11, 2020, 02:33:39 PM »
Stealing an idea from RickTomas http://forums.sohc4.net/index.php/topic,183277.0.html  and building a semi stock air box . I got a used air box on eBay just the air box I have a new set of stock air horns so here is what I'm doing. I can't use the stock air cleaner setup because of my electrics box . I clamped the air box to a 2x6 on the carb side and ran it through my band saw cutting off the intake side. The board ran against the fence to insure a parallel cut to the back side. The cutoff was used to trace the shape on  a leftover piece of azek 5/4 plastic trim lumber and then cut out with the band saw. I used the router table to make a lip that would let the assembly slide into the air box. Drilled some corner holes and cut the center section out with a jigsaw. A piece of perforated aluminum will hold the uni foam filter sheet in place. An aluminium drilled and powder coated front cover is get to be fabricated. Thanks for the idea Rick
Gary
« Last Edit: September 18, 2020, 06:01:54 AM by XC204 »
Offline XC204
« Reply #98 on: September 16, 2020, 07:23:43 PM »
Finished the air cleaner up today just waiting on my uni-foam filter material.
Offline kenjataimu
« Reply #99 on: September 18, 2020, 07:50:56 PM »
Gary
The level of organization you have for your wiring is erection inducing. This makes me feel ashamed of how I handle my wiring haha.
74' CB550 - Under Construction
