Author Topic: throttle return spring?  (Read 1049 times)
jmanstuck
« on: May 27, 2006, 10:22:02 AM »
 Hey excuse all the basic questions as this is my first bike & dont want to screw anything up. I knocked my throttle return spring off & can't see any obvious place to hook the bottom to. Thanks
Offline scondon
  • Mmmm......tasty bugs
Re: throttle return spring?
« Reply #1 on: May 27, 2006, 12:07:29 PM »
It would help to know the model/year bike and type of carbs.
jmanstuck
« Reply #2 on: May 27, 2006, 12:11:38 PM »
Yea it would sorry 1973 500 cb4.
Offline scondon
« Reply #3 on: May 27, 2006, 12:24:47 PM »
Sorry, I don't have any 500 carbs to look at. On the 750 the spring mounts to a small plate with a hole in the middle. The plate is located between carbs 2&3 and fits between the carbs in the same place that the fuel lines connect between 1&2,3&4 carbs. Possible the plate got bent and fell out depending on how hard you "knocked" the spring off?
JonZ1973CB500
« Reply #4 on: May 27, 2006, 12:46:56 PM »
I have a '73 Cb500 also. . . the spring hooks up on a little metal thingy that looks like the metal on a pencil eraser. . . it's held in between carbs 2 and 3. The little bugger is really hard to get to stay in while trying to line up the chokes and mounting on the carb backing plate.  You could use a piece of a bolt cut off I bet.  Maybe expoxy it into carb 2 and then it wont fall out when you put them back together on the mounting bracket.
thats it!
jmanstuck
« Reply #5 on: May 27, 2006, 01:45:48 PM »
Thanks got it on a few minutes ago. Took some thought and cursing but it is on. Thanks
