Author Topic: New fork seals - which goes first?  (Read 938 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: February 06, 2012, 01:13:11 PM »
When replacing fork seals, do you install the new seals and then the upper tubes through them, or do you slide them down over the uppers?
Offline mrrch
Re: New fork seals - which goes first?
« Reply #1 on: February 06, 2012, 02:05:28 PM »
I usually put the fork together then install the seals over the uppers (make sure they don't have any nicks or damage that will damage the seals)
my build
Offline Johnie
« Reply #2 on: February 06, 2012, 03:27:45 PM »
On all my bikes I install the seals first. Then put a little fork oil on the inside of the seal and slide the tubes through. Never had problem with damaging any seal. I use the old seal over the new one to tap it into place. Seems to seat well this way for me.
« Last Edit: February 06, 2012, 05:41:15 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Steve_K
« Reply #3 on: February 06, 2012, 04:13:46 PM »
I put the tube and fork lower together and from the top I slide the seal into the fork lower.  I use some pvc tube to tap the seal into the fork lower.  Works for me on any of my bikes.
Steve
Steve_K
