Author Topic: Garage Floor Epoxy  (Read 12281 times)
Offline Accolay
Re: Garage Floor Epoxy
« Reply #25 on: February 09, 2012, 12:02:50 AM »
Thanks for that detailed information. It's always helpful in making a decision when all the information is at hand. Still not sold on anything, but I have a few months before it's warm enough for the garage to be useful anyway.
1977 CB550F
« Reply #26 on: February 09, 2012, 12:30:59 AM »
No problem, if you want to know anything else, just ask....
Offline faux fiddy
  • bike in a box
« Reply #27 on: February 09, 2012, 01:08:13 AM »
I have some crap that I need to move out of the house. It was a two part thing that was freight damagerd and as I was looking at it at the habitat store, the guy said I will give you all of it for $20 or something like that.  I think it's mostly junk, maybe I can get one good out of four, and all the "flakes" made to throw on are all that is really good of any of it.
I found something in a can that is a one part gallon can that also is called 'epoxy' but an off brand.
If I was ever to have a clean , swept garage (never) maybe I could use the most available one part stuff and throw the sprinkles from the other stuff.
Not like the place is industrial, but the first coat [cheaply available grey one coat "epoxy"] with one part and sprinkles while it's wet should stick, what would I put over it  as a second semi-transparent piss coat?
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
« Reply #28 on: February 09, 2012, 01:14:26 AM »
Offline faux fiddy
  • bike in a box
« Reply #29 on: February 09, 2012, 02:20:17 AM »
Thnks RR, what I had im mind. That's the plan I guess.  I'll look at the cheap stuff at the donor store and see if it's compatible, I really like the idea of an epoxy type garage floor.  I figure a weekend and a coulple hundred bucks and elbows , or less, and it's a project that is done for my lifetime.
« Reply #30 on: February 09, 2012, 04:03:34 AM »
Fiddy, we do a lot of flake finish garage floors, bathrooms, kitchen bench renovations and lots of other applications,  if there's anything you need to know let me know.... ;)
Offline BeSeeingYou
« Reply #31 on: February 09, 2012, 05:41:46 PM »
can you do that in Sunrise Orange? :D
« Reply #32 on: April 24, 2012, 08:02:21 PM »
I know you guys will think I'm crazy, but I did tiled my garage. Bought the ceramic at a closeout for 50 cents/sq ft and layed it myself. It's a 3 car garage, here is my workbench area...
Offline BeSeeingYou
« Reply #33 on: April 24, 2012, 09:37:10 PM »
What...no polished marble? ;)  Looks like you did a nice job.  Probably fine for your climate....have my doubts about it holding up long term in our climate.  My only concern would be dropping a heavy tool or object and cracking tiles. Keep a few large sheets of cardboard handy for protection.  If you are really good and conscientious about getting a good bed of mortar with no voids you will alleviate cracking from high point loads like that full tool chest rolling around.  Large tiles like those require a trowel with with at least 1/4 by 1/4 or even 1/4 by 3/8 especially over concrete with it's dips and hollows.  Maybe even expensive leveling compound depending on the floor.  I did a repair for a neighbor (who had a less than stellar attention to detail) ;D  that had as his first tile attempt tiled his concrete patio with large tiles.  Not enough mortar and at least 10 percent where cracked after a short time.  Many others had large voids and would have eventually cracked so I broke them out and replaced....maybe 25% when it was all done.  You can detect a void by sound when running your hand over the tile.
« Last Edit: April 24, 2012, 10:33:13 PM by srust58 »
Offline mitch500
« Reply #34 on: April 26, 2012, 06:38:30 PM »
Benjamin Moores Patio and Floor is really good. Its a acrylic modified epoxy. Water clean up and durable
I highly suggest it... I am a Journeyman Red seal Painter and decorator and have lots of experience with it.
Offline fmctm1sw
« Reply #35 on: April 27, 2012, 06:51:17 AM »
POR 15 makes something like that if it wasn't already mentioned.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #36 on: April 27, 2012, 04:06:51 PM »
We use high quality epoxy's and give a 10 year guarantee, i wouldn't do that with any water based products.....
Offline mitch500
Garage Floor Epoxy
« Reply #37 on: April 27, 2012, 04:37:54 PM »
That's great! You an use what you use.... Obviously if you went with a true epoxy it would last longer...
I was simply suggesting this product for the average DIY'er.. Easy to find, use,clean up and is still really durable. We used this on our floors in our down draft rooms and paint booths. It is extremely user friendly. You maybe have to re coat it in a few years or touch it up... All in all best bang for the buck;)
« Reply #38 on: April 27, 2012, 04:56:21 PM »
No problems mate, I think for shop floors, especially where motors are being pulled apart and oil and fuel may contaminate, there is no substitution for a good heavy solids epoxy floor.
