Author Topic: Is it the Solenoid?  (Read 9538 times)
Offline w1sa
Re: Is it the Solenoid?
« Reply #25 on: March 01, 2012, 03:44:45 AM »
Did you clean and check the terminal connector/spade(s) before the meter test?....... Did you retry the starter?.......
If you've done these things and can repeat the tests with the same results several times.....and the starter solenoid still fails to operate as it should... ???, I can only imagine a loose/intermittent/poor connection/condition (power or ground), somewhere...................I'll give it some more thought tho'
Offline adr3naline
  • adr3naline
    • adr3naline
« Reply #26 on: March 01, 2012, 02:32:29 PM »
So, I've traced my g/r wire now to my clutch, and then into what would be my headlight. I've got continuity between one of the big open ended prong connector (#1 in picture)... but I'm not sure what's supposed to connect to that prong connector (#1). Does anybody else have a CB650 that might know?
My ground connectors were a little corroded inside the black pin connector (#2), so I washed those out with vinegar, brushed up the pins slightly, and I can get continuity through it now.
The #3 & #4 (headlight) bundles have temporary yellow screw cap connectors for now to be able to diagnose these issues.
I just need to know what #1 is supposed to connect with. Thanks!
2006 Yamaha Warrior
1982 CB900c
1979 CB650
Offline bobth1019
« Reply #27 on: March 02, 2012, 03:46:34 PM »
A bit of a issue... I cleaned the R/g ground connector and turned the key and smoke from the rectifier...melted it very nicely...at this point I'm thinking replace the harness and take it from there. Maybe not the best approach but for what it will run on ebay not so much. Question is if someone knows does a 1981 cb750c harness interchange with a 1980 cb750c harness? Mine is the 1980. Thanks
1980 cb750c
Offline bobth1019
« Reply #28 on: March 02, 2012, 04:01:03 PM »
Should have been more specific.... the 2 prong silicon rectifier
1980 cb750c
Offline w1sa
« Reply #29 on: March 03, 2012, 07:57:38 PM »
If the wire is green as it appears, it is quite likely an original spare ground connector.....could prove useful!
The '80 and '81 harness's carry different part numbers....should be similar, but I don'tknow the specific differences.....can anyone else help here?
Did you check the harness for absolute damage....it might be limited to the silicon rectifier/diode section and/or other repairable points?
Offline bobth1019
« Reply #30 on: March 04, 2012, 04:56:17 AM »
Thank you.... I saw the unmatching numbers and stuck with an 80 harness. Might be a non-fix but at the rate I'm going a spare doesn't seem like a bad thought. Actually replacing it will give me the chance to really go over connections and make certain they're clean, etc. If it creates more issues I can go back to the other one in any case. We shall see...should get it in a couple days. Thanks again.
1980 cb750c
