Author Topic: Rear shocks painted?  (Read 944 times)
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« on: June 03, 2006, 10:52:32 AM »
Were the insides of the shock top covers painted black?  I took the shocks apart and after sanding
through several decades of rust, I think I noted black paint on the bare metal.  I can't decide if I
should repaint them before putting the shocks back together.
BTW....a drill press (for force...not drilling  ;D) and a small hand built tool makes an easy way to
compress the springs to remove the hold on clips on the top.
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline puppytrax
Re: Rear shocks painted?
« Reply #1 on: June 04, 2006, 06:48:29 PM »
That's exactly what I used...   ;D  Except I just placed them upside down on two pieces of 1/4" plate to compress them...
Mine didn't seem to have any paint inside...but I painted them with gray Rustoleum primer just to inhibit rust...
In years past, I used my bench vise with a 1/2" hole drilled through the rear of the movable jaw...then fastened a piece of angle with a slot cut in it to the bench behind the vise...the sections on either side of the slot were angled...you placed the shock spring in the slotted angle, put a bolt/screwdriver/whatever through the shock bottom mount and the vise jaw protrusion...and tightened the vise to compress the shock spring...
Worked real slick...nowadays,  I can't find the slotted angle...   ::)
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
