Author Topic: Controls- will these ones work?  (Read 732 times)
Offline mjc425
« on: March 24, 2012, 05:16:28 AM »
I've been searching around for a new right hand control for my 72 cb500 and can't find anything oem.  I found this link in a previous thread here...
http://www.mikesxs.net/products-60.html#products
Will these work?  Which one will work best?
1972 Honda CB500
Offline Xnavylfr
Re: Controls- will these ones work?
« Reply #1 on: March 24, 2012, 06:51:11 AM »
Yes those can be used. Hopefully when they send them to you ,you'll get a wiring diagram!!
No diagram!! you'll need to read each wire as to what gets powered when you change switch position!!
The way I do this , hook a LOW amp battery charger leads to the  wiring of the switch,, USUALLY RED wire is power and groung to the switch housing, then just chase wires 1 at a time and label.
Since this switch is for XS650 you'll have to remove the connector that plugs to the bikes wiring and rewire seperately..
GOOD LUCK
try using this as a base
http://www.xs650.com/forum/showthread.php?t=61
Xnavylfr(CHUCK)
Offline mjc425
« Reply #2 on: March 25, 2012, 06:12:01 AM »
Another thought- I see lots of these on eBay but not really any for my year and engine size.  But would it be better/ok to keep in it Honda and may go with something from a 750 in the later 70's.
They all look like mine... How different are they really?
1972 Honda CB500
