Author Topic: Carb rebuild question - CB750K4  (Read 1859 times)
« on: April 18, 2012, 08:11:48 AM »
I am rebuilding a spare set of carbs for practice and am now in reassembly phase (one I get the needle jets out!). Question is - when putting the linkages back togther and opening the choke I am guessing all the sliders should go down to the same level. They dont and not sure what to change/adjust?
I think I have the linkages in the correct orientation (using my running bikes for reference). What else can I check?
Also the needle jets are not coming out smoothly -a little stuck - anyone with experience with getting these out?
thanks
Andy
Offline Elan
    • Vital Motor Parts
Re: Carb rebuild question - CB750K4
« Reply #1 on: April 18, 2012, 08:13:31 AM »
I had the same problem on mine Andy so I'm subscribing to this thread
76 750k
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: April 18, 2012, 09:25:47 AM »
Maybe one of the "arms" that connect the linkage to the actual choke plate has gotten out of its groove? As long as all of the linkages are lined up correctly there's not much else it could be.
As to the needle jets, I've used chopsticks with good results. Strong enough to push them out with a tap from a hammer, but soft enough not to damage the brass.
Offline somesuch
« Reply #3 on: April 18, 2012, 09:28:38 AM »
That is what I use as well.
« Reply #4 on: April 18, 2012, 10:55:12 AM »
Great idea on the chopsticks never thought of that. Not too worried about damaging them as I have new replacements but didnt want to damage the carb body.
Ill need to check the linkage arms as I dont recall touching them. I was thinking more about the length of the linkages as they can be made shorter or longer.
Thanks for the reply
Andy
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #5 on: April 19, 2012, 10:44:39 AM »
Oh yeah!! Forgot about the length adjustment. That's totally it. :)
« Reply #6 on: April 19, 2012, 11:44:14 AM »
Update - used a wooden pencil to get the needle jets out and that made it quite easy. They are now out and will be replaced with new ones. Thanks for the suggestions.
Now to figure out the linkages...
Andy
Offline Johnie
« Reply #7 on: April 19, 2012, 02:09:03 PM »
Andy...to get all the choke flaps the same you have to first put the carbs back on the rack. Then you pull the cotter pin out from the arm and rotate the choke arm to where you want it. Sort of a pain, but I had to do that on my K4 too.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #8 on: April 19, 2012, 07:58:44 PM »
Thanks Johnie Ill give that a try.
Thanks
Andy
Offline 1974cb550k
« Reply #9 on: April 19, 2012, 08:28:51 PM »
I just had the same issue. I believe i put them (carbs) together and tightened them to the rack/spring assy, then adjust the outer turnbuckles on both carbs so they allow the choke slides to fully seat and slide, then adjust the center turnbuckle. FYI the outers go in first then the center turnbuckle goes on last. It is a pain.
« Reply #10 on: April 20, 2012, 05:07:01 AM »
Thanks good info!
