Author Topic: headlight  (Read 1644 times)
Offline wormser
headlight
« on: April 19, 2012, 01:42:26 PM »
I don't know which wires to hook my headlight too can anybody help? I've looked at the diagram and its not helping because I have eliminated all the switches and electronics up front so now I just have a bundle of odd colored wires. I think I just need 12v and a ground?
77 CB550F
73 Norton Commando 850
Offline LesterPiglet
  • 1977 CB550F2
Re: headlight
« Reply #1 on: April 19, 2012, 02:22:03 PM »
Have you got the wiring diagram for it? Blue, white and green.
bollingball
Re: headlight
« Reply #2 on: April 19, 2012, 02:34:50 PM »
Lester is correct you will need three wires if you what high and low beam and a ground. For this you will need a 3 position Sw. high low and off. Do you still have the wires on the harness.
Ken
Offline wormser
Re: headlight
« Reply #3 on: April 19, 2012, 05:14:56 PM »
I just want the low beam and the headlight came with a blue, white, green, and yellow, but on the harness these colors aren't all there. The harnesses has a green but no blue or white. I mistaking had removed the old headlight without identifying which wires it was hooked up too. I'm hoping to just have low beam when I turn on the key, no switches.
77 CB550F
Re: headlight
« Reply #4 on: April 19, 2012, 05:41:55 PM »
If your bike's wiring doesn't match the wire diagrams, how could we possibly tell you what wires to hook up?
What is left of the bike that is in stock configuration?
Green is GND.  White is Low beam power, and Blue is high beam power.
The black wires (if you have those) come on (+12V) with the key switch in the on position, (if you have that).
Re: headlight
« Reply #5 on: April 19, 2012, 06:20:14 PM »
Really?
Offline CycleRanger
  • No comment about being an
Re: headlight
« Reply #6 on: April 19, 2012, 07:31:03 PM »
For the bike to be street legal I imagine that you will have to have both high and low beam.
Offline wormser
Re: headlight
« Reply #7 on: April 19, 2012, 08:03:14 PM »
Haha, thanks to all that responded I'll figure it out.
77 CB550F
