Author Topic: Changing Front Fork Oil '76 CB550F.  (Read 3141 times)
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« on: April 22, 2012, 09:22:07 PM »
After my recent tour with Godzilla on board, my shoulders & back copped a bit of a pounding from jarring through the bars. I've just found the bottle of Motul fork oil I used the last time I changed the fork oil & realise it's 'Heavy'.
The manual sais to flush the interior with solvent before adding new oil.
My question is what solvent would be suitable. The manual sais  not to use gasoline, I'm thinking maybe kerosene?
Any recommendations would be appreciated.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
Re: Changing Front Fork Oil '76 CB550F.
« Reply #1 on: April 22, 2012, 09:36:26 PM »
Good question- I've wondered about that at times myself. Looking foward to some hopefully erudite replies.
« Reply #2 on: April 22, 2012, 11:33:34 PM »
id fill it with atf,ride it or bounce it up and down and drain it.
« Reply #3 on: April 23, 2012, 01:07:03 AM »
I use mineral spirits for the flush.  I think kerosene would work, as well.  But, I think it is more 'oily'.  I wonder if mineral spirits has a lower viscosity?
Anyway, you just want to flush out any metal particles from erosion of the metal sliding on metal.
I don't think either kerosene or mineral spirits residue will alter the chemistry of the fork oil, installed afterward.
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #4 on: April 23, 2012, 04:34:31 AM »
+1, mineral spirits won't hurt the rubber or anything else, and removes grease and grime.  I would add that a complete disassembly, clean, and inspect is best.
Offline cameron
« Reply #5 on: April 23, 2012, 01:31:19 PM »
Best, plus hardest and most painfully time consuming!
1976 CB550F
Offline LesterPiglet
  • 1977 CB550F2
« Reply #6 on: April 23, 2012, 01:33:49 PM »
I have down to an exact science now after the threads stripped in my fork bottoms. It helps if you have the special tool. A whittled piece of wood to act as wedge to stop the innards turning.
Offline mono
  • Definitely no
« Reply #7 on: April 23, 2012, 01:41:55 PM »
huh? what?  wedgies? strippers?
really - what stripped out?  now you've got me worried since i plan on doing this myself this week.  tips/things to watch out for?
  • 1977 CB550F2
« Reply #8 on: April 23, 2012, 01:49:42 PM »
The threads that hold the fender and brake caliper were stripped on mine. I had to take them apart to remove all the metal filings after getting them repaired.
Offline Bailgang
  • Scott
  • Indiana
« Reply #9 on: April 23, 2012, 02:48:43 PM »
The biggest issue I had with mine was trying to prevent the shallow allen head cap screw for rounding out when initially breaking it loose. Some come off easy some don't'
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
  • 1977 CB550F2
« Reply #10 on: April 23, 2012, 03:12:24 PM »
For that allen screw use a power tool. A quick spin frees it up.
Offline Frostyboy
  • Circa 1951
« Reply #11 on: April 23, 2012, 05:04:40 PM »
Thanks for the responses. I'll go with  the mineral spirits & see how it goes before pulling 'em apart.
We haven't met yet.
[CB550F1]
« Reply #12 on: April 24, 2012, 12:52:36 AM »
on forks that havent been apart for a long time i give that allen bolt a decent knock with a brass drift first.
Offline Frostyboy
  • Circa 1951
« Reply #13 on: April 26, 2012, 11:18:53 PM »
Well after a few searches of hardware stores trying to find Mineral Spirits with no joy, I was about to buy Kerosene to do the flush. No such thing here apparently, well at least not by that name.
It appears that here in Aus, it's known as Mineral Turpentine which you can buy just about anywhere.
Go figure  :o
We haven't met yet.
[CB550F1]
« Reply #14 on: April 26, 2012, 11:24:25 PM »
i buy kero in 20 litre drums to use as parts cleaner?from a shell depot,coles/woolies has it in one litre bottles.
« Reply #15 on: April 26, 2012, 11:56:47 PM »
Mineral spirits is also called paint thinner here in the states.
« Last Edit: April 27, 2012, 03:57:37 AM by TwoTired »
Offline trueblue
« Reply #16 on: April 27, 2012, 01:58:56 AM »
Here if you go into a shop and ask for paint thinners you won't be given turps.
1979 CB650Z
