Author Topic: 78 CB750 Slow jets  (Read 31598 times)
Offline Kev Nemo
  • Honda Hacker
  • http://fallingapartart.com/
    • FallingApartArt
Re: 78 CB750 Slow jets
« Reply #75 on: August 15, 2012, 08:02:33 AM »
Hell yes!! OK, so when I get my #42's in I'll pop these on as well and hopefully, as they say, that will be that :)
Now to fix that head gasket leak...... :(
Ha- just got mine out of the shop for the head gasket leak.
@Lucky I meant to say "tuning", not syncing. If you're trying to track down all the possible culprits for slow response and smooth operation, something that's not that obvious would be a headache.
Destroyed by Design since 2009 http://fallingapartart.com/
- '78 CB750k bobtrack
Offline lucky
« Reply #76 on: August 15, 2012, 04:13:01 PM »
ALL engine issues must be resolved before you can work on carbs.
Hey,Thanks for letting me know what is going on.
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #77 on: August 16, 2012, 07:42:13 AM »
And with these bikes, when it rains it pours. Now I'm looking at new coils, because my plug wires have reached their cut-down limit, which means I have to get new coils, too. FML
« Reply #78 on: August 16, 2012, 07:55:12 AM »
just splice in new wires  8)
« Reply #79 on: August 16, 2012, 10:12:52 AM »
NGK makes ignition wire splicers.
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #80 on: August 16, 2012, 11:18:20 AM »
Really- do you have a link?
« Reply #81 on: August 16, 2012, 11:30:14 AM »
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #82 on: August 16, 2012, 02:35:58 PM »
Z1 Enterprises sells the splicers as well. Pat
Regards
Pat from Australia
Offline lostmykeys
« Reply #83 on: August 16, 2012, 04:11:44 PM »
Lucky,who did you say brought the brass restictors to you attention?
Offline lucky
« Reply #84 on: August 16, 2012, 04:43:04 PM »
Brewsky was the man.
He is very methodical and detail oriented.
He keeps good records too.
Offline lostmykeys
« Reply #85 on: August 16, 2012, 05:29:24 PM »
Lucky,Are you sure? I have saved Pm's from you that show your exietment when I brought this topic up in May.Should I post them?
Offline Damfino
« Reply #86 on: August 16, 2012, 06:51:23 PM »
As per the rules of this forum, that would get you in trouble. I suggest you read the rules of the forum....
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline lucky
« Reply #87 on: August 16, 2012, 07:02:12 PM »
I am trying to figure out what you want LostmyKeys.
What are you thinking?
What I told you is true. Brewsky was rebuilding his carbs and discovered the small pieces of brass tubing in the black hose between the carbs in the accelerator pump circuit and when he told me, I was excited because fortunately I had saved those little black hoses in case I wanted to know the exact length later on. Very fortunate.
« Last Edit: August 16, 2012, 07:06:31 PM by lucky »
Offline lostmykeys
« Reply #88 on: August 16, 2012, 08:31:03 PM »
 Lucky, I think I was the one to bring those brass restictors to your attention.
  Do I have to prove it !
 Scmuckass,if this forum is against free speach...then speak up and PM me.
 If you dont want to be proven wrong then stfu.
 If I get kicked off of this forum just because I spoke against the the posters with ill info,then maybe I had a chance to wake up those who think for themselves.
 All I'm trying to say is this......if you dont know what your talking about STFU.
 Do you guys realise that there may be thousands of guys looking at this forum and needing help with their new found treasure?
  Give good advice without tooting yor own horn.If you cant provide good advice then STFU.
  If you can respond to this DO IT.
Offline lucky
« Reply #89 on: August 16, 2012, 08:44:12 PM »
Why didn't you just say it was you?
I believe you. It has been a while so I could have got it wrong. Sorry.
The forum is not against free speech.
All you had to do is say it was you that discovered the bras tubes.
No one would challenge you.
Now do We get a hug? Lol..lol
Offline lostmykeys
« Reply #90 on: August 16, 2012, 08:56:18 PM »
 Lucky,I just like to be called Lostmykeys over Brewsky.
 When you call me Brewski it makes me feel like a lush....which I am...Ha!
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #91 on: August 17, 2012, 10:53:15 AM »
Offline lucky
« Reply #92 on: August 17, 2012, 10:58:51 AM »
Sorry "Lost my keys" Lol..lol
But why did you lose the keys? Drinking?
Some kind of metaphysical connections here
Lostmykeys and Brewsky  Came together unintentionally. Hmmmm
Something to contemplate during the day.
Offline surveywaters
    • My Project Photos
« Reply #93 on: July 28, 2013, 01:48:37 PM »
Sorry to drag this thread back up but I found it very informative and specific to my question so this may help others. The press fit slow jets are difficult to find and much more expensive then other pilots, but I cameacross this statement at motorcyclecarbs.com :
---------Honda CB750's and some other late 60's and 70's Hondas with Keihin Carbs have a press in jet that looks like the N424-22. The Press In version is no longer available, but the N424-22 series jet is actually the right jet only it has threads on it. The threads are the right outside diameter, and you can just add a healthy application of blue or purple locktite to seal the threads even though the threaded jet presses in nicely.------
Anyonehave an opinion on this? It's the difference between $8.50 and $42 for the jets.
1972 SL125,1974 XL125,1975 CB125,1978 CB750k,1978 KZ650,1978 XS650,1985 VT1100,1986 VF700, 2005 XV1700,2003 DL1000,1982 XR250R,1986 ATC70,1987 BW80,1987 XR250R,1999 Z50r,2002 DRZ400s
« Reply #94 on: July 28, 2013, 06:27:16 PM »
You should give ita try and then put it in Tips and Tricks.
    • My Project Photos
« Reply #95 on: July 29, 2013, 04:51:35 AM »
I did order them and will be sure to update.
« Reply #96 on: July 29, 2013, 10:26:51 AM »
Wasn't it Buffo that did the glue in jets thing a few years ago?
Personally, I'd thread the carb bodies rather than glue in.
    • My Project Photos
« Reply #97 on: July 29, 2013, 03:48:46 PM »
According to the link I posted, the lock tight is not necessary as the od of the threads as well as the short smooth section are the same size as the press in. The lock tight is just to seal the threads.
