Author Topic: Is there a reverse-table for Honda part codes?  (Read 970 times)
Offline Raul CB750K1
« on: June 13, 2006, 02:19:25 AM »
I need some oils seals for the forks of my Sanglas bike. Problem is that Sanglas shut doors two decades ago...
As seals are pretty much standard, I was wondering if there is a way to know a Honda part code -if any- for an oil seal that measures 42 x 52 x 8. While some other parts, as bolts, form the part code depending on the measurements, oil seals are not the same. Can somebody help with that?
Best regards
Raul
Online bryanj
Re: Is there a reverse-table for Honda part codes?
« Reply #1 on: June 13, 2006, 05:44:58 AM »
Raul if i get chance this weekend i will try and go to a shop i know and check out the aftermarket books. would you like me to get a set for you if i can as part of what i owe? Email me direct/ Regards Bryan
Offline dusterdude
« Reply #2 on: June 13, 2006, 07:56:17 AM »
there is an outfit here in the states called tcm,their part number is 42x52x8tc.if you cant find any,let me know ill get you a couple.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #3 on: June 13, 2006, 08:16:17 AM »
Thanks a lot Duster. I made a couple of phone calls and found a bearing shop that will have a set for me on thursday. I will post with the result.
They should be just fine, provided that oil seals and bearings are just standard and not brand-related. As long as the quality is good...
Raul
Offline dusterdude
« Reply #4 on: June 13, 2006, 11:04:27 AM »
im here for ya bro.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
