Author Topic: CB550 unknown exhaust  (Read 3697 times)
Offline grahamsn
« on: May 23, 2012, 07:53:06 PM »
Is anyone able to tell me who manufactures the CB550 exhaust in the below pic?
Offline brooze72
Re: CB550 unknown exhaust
« Reply #1 on: May 23, 2012, 08:05:02 PM »
Check the exhaust photo reference library, it is probably in there.
http://forums.sohc4.net/index.php?topic=97959.0
1972 CB500K1 - restored rider
1981 CB650C - new project
Offline ngonerogwu
  • cb350/550
« Reply #2 on: May 23, 2012, 08:05:53 PM »
Looks just like the hooker I have. I don't have the correct exhaust clamps, so I had to take it off :-(
Offline Tews19
  • I am no
« Reply #3 on: May 23, 2012, 08:08:11 PM »
4-1 exhaust systems Triple Accessories, inc
Here is a pic of there advertisement from back in the day
« Last Edit: May 23, 2012, 08:10:18 PM by Tews19 »
1970 Honda CB750 survivor.
Offline grahamsn
« Reply #4 on: May 24, 2012, 06:41:00 AM »
Thanks very much guys.  I didn't know about the exhaust ID thread!
I believe that you're 100% correct.  May I ask about the problem you encountered with your exhaust clamps?  They look to be the same as mine.
« Reply #5 on: May 24, 2012, 07:31:04 AM »
 I think Hooker, look at the collecter and muffler..
Offline ngonerogwu
  • cb350/550
« Reply #6 on: May 24, 2012, 01:06:39 PM »
The spigots we have are the same (came with the hooker, not the same as OE)
The half moon things tht press between the spigots and head are different. The hooker pipes are larger diameter than the stock pipes, so those half moon clamps don't fit around the hooker pipes right.
Anyways, I'd certainly like the hooker to fit properly, it sounds glorious.
Offline Lostboy Steve
« Reply #7 on: May 24, 2012, 01:38:34 PM »
Whats that going on right behind you caliper? Just curious..
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #8 on: May 24, 2012, 01:39:16 PM »
You can modify a set of stockers to fit if you've got a grinding wheel ;)
Offline LesterPiglet
  • 1977 CB550F2
« Reply #9 on: May 24, 2012, 01:42:18 PM »
Behind the caliper? You mean the totally irrelevant umbrella to stop water getting on the disc that comes standard?
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #10 on: May 24, 2012, 04:36:52 PM »
I think they are referring to exhaust collars but to answer your question the brake hoods are not irrelevant at keeping fork oil from seeping onto your disc! And these forks will leak eventually. Ask me how I know.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
  • 1977 CB550F2
« Reply #11 on: May 24, 2012, 04:44:36 PM »
That was in reply to twisted's q. I don't think I'll ever get to the point where oil drips from my forks.
Offline ngonerogwu
  • cb350/550
« Reply #12 on: May 24, 2012, 06:07:26 PM »
I'd love to see how, I bent a spare set of stock ones to match the curve of the larger pipe, but they leaked at the head (with new gaskets)
« Reply #13 on: May 24, 2012, 08:07:45 PM »
 Post where you are..  Myself I would measure it up, machine a flanged bushing X4 that fits, then split em on the saw. That would fix.. many aftermarket exhausts came with their own collar sizes.
Offline xsmooth69x
« Reply #14 on: May 24, 2012, 08:11:24 PM »
or about that exhaust not fitting u can always just send it to me and ill ummm hold it for you until u get an exhaust that will fit  ;)
freaken sick ass exhaust though wish i could find one!
idk if its just the camera angle but do u have to drop the exhaust to get to the oil filter? because it looks like on of the pipes kinda come infront of it
1975 CB550 (FINISHED?!?!?)
Offline ngonerogwu
  • cb350/550
« Reply #15 on: May 25, 2012, 06:24:57 PM »
I've just heated and hammered them. Machining a flanged bushing sounds awesome. I may try and cut thm in half, might fit better.
I do love how it looks, just wish i had the right parts.
I went ahead and ordered a motogpwerks yoshi copy. Its really well made, but not near as cool.
You gotta pull the exhaust for an oil change.
« Reply #16 on: May 25, 2012, 08:56:47 PM »
 I think you read me wrong, you machine a (carefully measured up) bushing with a projecting lip ..called a flange bushing..cut that in 1/2 make 2 pieces = enough for 1 pipe..
 Got ones that dont fit ?.. cut them all you want.. still wont fit...
