Author Topic: Clutch question 74 cb550  (Read 1634 times)
Offline Gurp
  • I'm no.......
  • Once was a...
« on: June 16, 2012, 03:33:08 AM »
So my clutch lever is extremely hard to pull. if i adjust the cable so it feel like it should  my kickstarter wont engage the engine. and this is a issue bc i run kick only.. it also wants to pull forward in first with the clutch lever pulled in.
i know this is prolly a dumb question.. i think i need a clutch but i figureed  would get thhe input of ppol how know alittle more on the subject..
Thanks Ron
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline LesterPiglet
  • 1977 CB550F2
Re: Clutch question 74 cb550
« Reply #1 on: June 16, 2012, 05:37:42 AM »
sounds like your clutch plates are sticking. Take them out and clean them. Also any ridges you find on the clutch basket, file them smooth.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #2 on: June 16, 2012, 12:02:07 PM »
that sounds right to me considering before i got it it hadnt been started in a few years.
« Reply #3 on: June 17, 2012, 04:38:38 AM »
Only once I bought an aftermarket clutch cable. Hanging freely it felt just fine, once installed it was a different story. The difference between this thing and a new OEM was incredible. I'm sure it's not only the cable causing your problem, just something else to consider.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #4 on: June 17, 2012, 04:13:33 PM »
well its kinda rigged cable... its off a suzuki. its but im not sure if that was the cause.
thanks ill consider this too..
btw does anyone know how to clean the clutch or tell if its overly worn??? im sure its diff then on a car or truck lol
