Author Topic: Engine install trick I found  (Read 5924 times)
Offline mwtt6
« on: June 20, 2012, 06:08:57 AM »
I found that having the oil pan and sump off the engine when reinstalling gives that extra clearance it needs. We slipped it back in in minutes!
Offline boatsdickson
  • 1978 836 K8
Re: Engine install trick I found
« Reply #1 on: July 08, 2012, 05:41:08 PM »
Good trick for clearance to the frame yes but can you imagine the damage that will happen to the pan gasket surfaces or oil sump mounting area if you slip and drop the motor....
Good if it worked for you but I dont have the balls. Congratz on your install btw....Boats
---Edit: Think Ill try this next time if I can have a plate of metal machined a few 1/8" thick and bolted in place where the oil pan and pump would normally go. JIC.
« Last Edit: August 11, 2012, 01:11:40 AM by boatsdickson »
"No. We're all our own prisons, we are each all our own wardens and we do our own time. I can't judge anyone else. What other people do is not really my affair unless they approach me with it. Prison's in your mind. Can't you see I'm free"?  Testimonial of Charles Manson
Offline nomad20012
« Reply #2 on: August 10, 2012, 07:21:17 PM »
Definitely going to remember that one when I go to put it back in, but will do it laying on it's side until I can bolt her in then turn right side up and put on the pan.
Good tip.
Offline 74750k4
« Reply #3 on: August 22, 2012, 02:17:18 PM »
That would be my technique...
Offline Elan
    • Vital Motor Parts
« Reply #4 on: August 22, 2012, 02:20:10 PM »
yup and I ground down the "lip" of the lower front mounting bracket on the frame, helps as well.
76 750k
Offline 74750k4
« Reply #5 on: August 24, 2012, 03:04:35 PM »
Is there a photo of that mount grinding area on here somewhere ???
Offline Mike the bike
« Reply #6 on: October 28, 2012, 01:51:16 PM »
I made a small table from MDF, 11.25 inches high.  I placed the engine on the table, minus the sump, and slid it across.
Next I just fitted the lower engine bolts and jacked the engine forward with a car jack to make fitting the carbs easier.
If you can't see light at the end of the tunnel, go down the tunnel and light the chuffing thing yourself
Offline Kevin D
  • SE Michigan
« Reply #7 on: October 28, 2012, 02:38:50 PM »
grind the right motor mount a bit - Hondaman tip
71 CB750 K1
106,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline beach bum
« Reply #8 on: December 13, 2012, 07:37:11 PM »
Thx for the pics
