Author Topic: 1976 cb550 gasket swap  (Read 724 times)
Offline bboyroxas
« on: June 26, 2012, 05:58:35 PM »
Hello what is the easiest way to replace the head gasket on a cb550 mine is leaking somewhat when I am at high speeds and it looks like it is going to be a long job
Offline cabrala
  • Super Duper
Re: 1976 cb550 gasket swap
« Reply #1 on: June 26, 2012, 06:06:05 PM »
I've been told to hold off on my head leak, and if yours is truly "somewhat leaking", I'd advise you to do the same. Believe me, I want my bike leak free, but pulling the head will lead to other fixes and other maintenance that really should be completed when you get that far into the engine.
The solution that some will use is nylon rope or paper towels rolled into the fins so that oil is soaked into those bits instead of your pants or boots. How bad is the leak really??
-Alex
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
Need a better, newer points cover gasket? How about rubber washers for the headlight bucket? Click the link below:
http://forums.sohc4.net/index.php?topic=122308.0
