Author Topic: Honda CB750A Hondamatic diy carb insulators  (Read 4668 times)
Offline jukku
  • Happy with my Hondamatic
« on: July 06, 2012, 10:10:23 AM »
Honda CB750A Hondamatic diy carb insulators ;D
The World Leader in Performance Silicone Hoses 2012
PE90 - 90° Elbow
I.D. (mm) I.D. (") Wall Size Leg Length   Part No.   RRP (Ex VAT)
32 mm     1 1/4"   4.2mm    102mm        PE90/32  £23.38    (Classic Black    +15%)
Fuel Resistant - ProFuel™ Lined Elbows :
The World’s first Performance Silicone hose for permanent fuel use. Suitable for transport
of Petroleum & Diesel Fuels –can be used for fuel lines, delivery, filler and breathers.
Also Available on most race parts. 2 Year Warranty. Supplied with ProFuel™ green lining.
Standard Colour Options : Blue / Red / Bright Green / Yellow / Purple / Black / B.R. Green / Orange
Premium Colour Options (+15%) : White / Pink / Classic Black / Gunmetal Grey / Viper Red
(+35%) : Silver / Samco Blaze / Urban Camo / Solar Orange Camo / Lightning Blue Camo / Ninja Green Camo
Max Temperature : 180° (356°F)
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: Honda CB750A Hondamatic diy carb insulators
« Reply #1 on: July 06, 2012, 10:32:03 AM »
Seen this before - thanks for putting it here.
The air flow path won't be as good as stock - but when you don't have any other options, you make do. . . .  ;)
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline POPS 911
« Reply #2 on: July 09, 2012, 08:36:14 AM »
COST: I have seen these HOSES sell for 20-35 dollars per hose at a hose supply [ commercial ] shop in my town.  So do you buy two and cut in half to make the bends ????  I use Mr. Weeks fix of the CB750F boots and mounted my XJ750R SECA carbs on my 750A HONDAMATIC race bike and with these CV carbs and reversed cone muffler spun up on my home made dyno = power.............  I have many sets [ 26,28,29,31,33,38's of carbs but none worked better with stock jets than the YAMAHA 750 SECA on this hard to mount [ 4 INLINE ] carbs on the  HONDAMATIC 750A.
For 6 months I tried every combination of hoses, boots and carbs and could not get a idle or top end that was good !!!!!!!  Thanks to MR. HONDAMATIC for the tip on CV carbs and stall on auto transmisson = you think I would have known that from my CM400A HONDAMATIC [ CV CARBS ] drag bike that I have went many rounds on over the past few years ?????
POPS BK911 ST/ET NHRA
Offline RBsHonda
« Reply #3 on: July 18, 2012, 08:57:10 PM »
I have a '77 CB750A with dry rotted and cracked carb insulators and am looking for a solution. How are these working out for you? Any issues so far? Thanks.
Offline Blucav85
« Reply #4 on: August 25, 2012, 09:39:47 AM »
Has anyone else tried this? At 69.03 msrp for one hose that's a expensive trial and error for me
Offline jukku
« Reply #5 on: August 30, 2012, 12:24:48 PM »
Hello
These diy carb insulators is workin well on three Matics. Two with sidecar and one solo.
If you can´t get better then these are good enough  ;D
Offline xntrik
« Reply #6 on: September 17, 2014, 11:11:59 PM »
Jukku, interested in making a set? U seem like a pro... ;)
