Author Topic: white fiberglass  (Read 1260 times)
Offline 2wheels
white fiberglass
« on: July 18, 2012, 05:21:21 AM »
I have a tent trailer that has a white textured fiberglass roof.
Unfortunately with a bicycle handle bar hole in it now.
I think a layer of fiber glass would be the right way to fix it.  But the only fiber glass I have ever seen is yellow and would look bad.
How do they get white fiber glass?
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
Re: white fiberglass
« Reply #1 on: July 18, 2012, 07:45:37 AM »
Using coloring in the resin. Find a marine/boat shop and ask the same question. They should be able to help you.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #2 on: July 18, 2012, 07:45:46 AM »
Paint.
« Reply #3 on: July 18, 2012, 09:01:25 AM »
Gel coat is what the white probably is. I made some fiberglass dragster noses with white gell coating. you may end up painting it. Maybe a graphic or stripe that would cover the repair.
Offline 2wheels
« Reply #4 on: July 18, 2012, 09:34:03 AM »
Ok, thanks.
I found resin coloring on ebay.
http://www.ebay.ca/itm/EVERCOAT-100508-BLACK-FIBERGLASS-RESIN-COLORING-AGENT-1-OZ-TUBE-/110909666287?pt=LH_DefaultDomain_0&hash=item19d2bb33ef
I will get a tube of white and experiment.
Painting was my second choice.
Much appreciated.
Offline 333
  • Time for change
« Reply #5 on: July 18, 2012, 09:37:02 AM »
You may end up painting the whole thing anyways, if you mind that it doesn't match.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
