Author Topic: 1981 CB650C Front Brake Locked - Can't find Master Cylinder return  (Read 1436 times)
Offline mn_rideit
Riding home from work yesterday, about 5-10 minutes into the ride the bike started to slow down.  I noticed the front brake was locked.
I've searched the forums and read several threads about the return hole in the master cylinder being blocked.  Though looking into the MC reservoir I don't see anything that could be the return hole.
I'm planning to pull off and rebuild the calipers this weekend, but wanted to also check/clear the return hole if at all possible.
Where is it in this picture?
Offline onepieceatatime
Re: 1981 CB650C Front Brake Locked - Can't find Master Cylinder return
« Reply #1 on: July 21, 2012, 01:54:13 PM »
The return hole is in the metal housing below the plastic cup. You must remove the cup to access the return hole.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline mn_rideit
« Reply #2 on: July 21, 2012, 02:26:12 PM »
Are there any instructions on how to remove the plastic cup/reservoir?
Offline scunny
  • don't call me expert
« Reply #3 on: July 21, 2012, 03:02:32 PM »
it's a bugger to get out, but I used 2 knives(dinner ones not sharp) slip them in and twist them.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline JimJamerino
  • Yay! I'm a
  • Not rich enough to be "eccentric."
    • My CB650C build thread
« Reply #4 on: July 21, 2012, 03:55:14 PM »
I used a big screwdriver. It doesn't want to, but it can be coaxed out.
~ Jim
formerly "emperorspartacus"
There are old bikers.  There are dumb bikers.  There are no old, dumb bikers.
My CB650C rebuild http://forums.sohc4.net/index.php?topic=74212.0
Offline mn_rideit
« Reply #5 on: July 21, 2012, 04:40:18 PM »
Thanks guys.
I popped it off, cleaned the returned hole underneath which was blocked as suspected.
