Author Topic: 1979 Goldwing front end  (Read 2833 times)
Offline Tews19
  • I am no
« on: August 18, 2012, 12:37:38 PM »
is this a direct bolt on and upgrade in suspension for a 750? Looking to build a cafe with one of my spare K1's
1970 Honda CB750 survivor.
Offline Tews19
  • I am no
Re: 1979 Goldwing front end
« Reply #1 on: August 18, 2012, 12:52:01 PM »
I should state I have searched and most threads recommend the 75-76 GL front end.
Now The 79 I have found has gold anodized rims, 19 front 17 rear. i thought the 79 GL's came with comstars? I like the spoke look and want to keep the same theme.
« Reply #2 on: August 18, 2012, 12:54:37 PM »
A lot of guys use the GL front end for an upgrade to braking - dual front discs.
Offline farmertom
  • Owner of many cb750s
  • MBS - anonymous
« Reply #3 on: August 18, 2012, 01:16:09 PM »
I have recently put a '76 GL front end on a '71 CB750.  Direct bolt-on.  Switched to tapered roller steering bearings in the process.
'76 cb750a
'77 cb750a
...and many K's
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #4 on: August 18, 2012, 01:22:57 PM »
The spoked wheel front end you have is probably off a 1976 "LTD". They were a limited edition that came with gold accents. 75-77 GL have spoked wheels, 78-79 GL has comstars.
Click on the link in my signature.
  The 3rd pic shows the differences between the early and late GL front ends. The mounting lugs for the calipers on the early forks are wider apart than the later years (pic of the late front end was converted to early spoked wheel)
« Last Edit: August 18, 2012, 01:26:36 PM by fishhead »
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline Tews19
  • I am no
« Reply #5 on: August 18, 2012, 01:33:33 PM »
Sweet! Fish I saw you on a number of threads with the GL front end conversion. This is the set up.
Offline Tews19
  • I am no
« Reply #6 on: August 18, 2012, 01:34:07 PM »
Is this not a nice swap to do? Also the rear rim is a 17. Not sure if I should do it.
« Reply #7 on: August 18, 2012, 01:41:03 PM »
What are you trying to gain?
Offline Tews19
  • I am no
« Reply #8 on: August 18, 2012, 01:48:16 PM »
Improved handling and braking. This will most likely be used on the green chopper k1 if I use it to make a nice cafe
Offline fishhead
« Reply #9 on: August 18, 2012, 01:48:35 PM »
The GL front swap is the first thing I would do (my opinion). Sturdier forks, better brakes. Loose the GL front fender though. The K idiot light handle bar clamp thing bolts to the GL forks, but the K gauges would need the mounts removed and widened/re-welded for the GL top clamp.
The tapered bearing kit for the CB K fits with the GL forks.
« Reply #10 on: August 18, 2012, 01:52:27 PM »
My K8 has a 17' rear rim and it is wider than the earlier model. Hence, you can put a wider tire on it, which I did.
Offline Tews19
  • I am no
« Reply #11 on: August 18, 2012, 01:56:28 PM »
So the front end is the LTD from a 76?
Offline Tews19
  • I am no
« Reply #12 on: August 18, 2012, 02:00:08 PM »
The rear wheel also is disk.
« Reply #13 on: August 18, 2012, 02:27:09 PM »
You sure you want to buy that? Doesnt look like its in very good cond
Offline Tews19
  • I am no
« Reply #14 on: August 18, 2012, 02:33:49 PM »
havent committed yet.. more interested with the front suspension.. dont care for the rim shape..
