Author Topic: Float bowl woes  (Read 1242 times)
Offline Mooshie
Float bowl woes
« on: August 20, 2012, 02:29:37 PM »
I have a stuck float bowl that leaks intermittently.  Time to go in and pull the rack and have a look. I thought while I was doing that I might as well look at all of the needles and seat, gaskets, etc.  Question #1 is where to buy needles and seat.  I found them at Parts n more for $8.50 a set  http://www.partsnmore.com/parts/honda/cb550f/?filters[category]=carb&filters[fitting]=custom
Then I found them at Hondapartsline.com for $23.00 per set http://www.hondapartsline.com/fiche_section_detail.asp
That is quite a difference.  Is one OEM and the other not as good quality?  both have the same part # 16011-329-004.  If one is better I would rather spend the money but if that is not the case then $8.50 sounds good to me.
Question #2 is should I just wait until I pull the carbs to buy the parts I need?  I know that slows down the repairs but at least then I would not be buying something unnecessary.
Thank you for your help... :-*
1976 CB550F
Standard disclaimer: Remember I am just a girl--so be nice fellows!
Offline aperry
Re: Float bowl woes
« Reply #1 on: August 20, 2012, 03:06:08 PM »
While pulling the carbs and giving them a good cleaning is never a bad thing, there is also quite a bit that you can do to troubleshoot leaking float bowls with the carbs still in place.  I believe on most of these carbs the float valve and seat can both be replaced just by removing the bowl.  Another cause can be a "dimple" that forms on the float tang after decades of use.  This can be removed and carefully sanded without removing the carbs as well.  At least all this can be done on my 657a (750K3) carbs.
Just thought I'd mention it.
I can't really help with advice on the aftermarket parts.  I rebuilt mine from the partsmore carb rebuild kit.  Some of the replacement parts in the kit appear to be genuine Keihin, but others aren't quite as clear.  So far I haven't had any carb issues that I can blame on these carb rebuild kits.
Aaron
CB750K3 with F1 frame/swingarm
Offline lucky
Re: Float bowl woes
« Reply #2 on: August 20, 2012, 03:17:21 PM »
If it has been a couple of years replace those needles and seats.
bollingball
Re: Float bowl woes
« Reply #3 on: August 20, 2012, 03:21:22 PM »
How stuck is the float bowl? Try to tap it to break it loose then you can get inside.
Ken
Unless you meant something else. ;)
Offline DJ_AX
Re: Float bowl woes
« Reply #4 on: August 20, 2012, 03:37:18 PM »
I've gotten the (non-rubber tipped) inexpensive ones from PnM... they work for me.
I've had rubber ones degrade and fall apart on me before... too much ethanol?
Offline Mooshie
Re: Float bowl woes
« Reply #5 on: August 20, 2012, 03:41:22 PM »
Ken
I have tapped it numerous times and it always works (stops the leak) for awhile then comes back sometimes as much as months and months later.  The leak is intermittent (no rhyme or reason to it occurring but it is usually in the mornings after a hot day/ride).  Thought I should stop it once and for all instead of hitting it with a screwdriver handle each time. It is always on the #3 carb.
It has been over 4 years
Aaron
Can I get to the #2 and #3 on a CB550 without having to join the circus to twist into the spaces I would need to for removing the bowls?  I was also going to put on new intake manifolds so thought pulling the carbs would be a good way to go since I have to for that operation  ;)
Were they the $8.50 ones I am looking at?  That would be perfect.  I too was looking for the non-rubber tipped, especially if they worked well
1976 CB550F
Offline DJ_AX
Re: Float bowl woes
« Reply #6 on: August 20, 2012, 03:58:43 PM »
Yeah they were those exactly..
some thoughts ...
Lately, my 750 has been giving me intermittent issues like you describe. and now my petcock is developing a leak.  :P bad combo...
Anyway I attribute my probs to no sock filter in a slightly rusty tank... and the cheap inline filter not catching everything.. maybe even some of that rust sediment caught up in the fuel line after the filter that eventually gets dislodged.
I'll soon be disassembling and replacing some things in the system :)
