Author Topic: Rebuild Shopping List  (Read 1174 times)
Offline Sdsbassist
  • Gus, Austin, MN.
« on: August 23, 2012, 07:09:18 PM »
So I am rebuilding the motor over the winter. My motor is a 78K model engine.
I want to start a shopping list now.
I will need:
A gasket set:
http://www.ebay.com/itm/74-78-CB750-ENGINE-GASKET-SET-CB750F-CB750K-/190665078502?pt=Motorcycles_Parts_Accessories&hash=item2c648636e6&vxp=mtr
A honer?
Beer:
What else should I shop for? What are good things to do if I am likly going to split the case anyways. Does a "complete gasket set really come "complete?"
Thanks guys. I will be starting a thread for the frankenstein rebuild :)
« Last Edit: August 23, 2012, 07:18:02 PM by Sdsbassist »
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Re: Rebuild Shopping List
« Reply #1 on: August 23, 2012, 07:27:48 PM »
Grain Belt....WTF??
Get a DP 1000 kit! He's in Austin.
http://www.dynoman.net/engine/pistons/custom.html#cb750
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #2 on: August 23, 2012, 07:34:24 PM »
Austin, mn, not texas. Grain belt is the official beer of minnesota. Delicious.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #3 on: August 23, 2012, 07:36:03 PM »
Im looking more to stop the oil leaks. And give her a cleanup amd makeover.
Gus, Austin, MN.
Offline cgswss
« Reply #4 on: August 24, 2012, 04:43:25 AM »
I would not split the cases unless you have a good reason to do so.  I would do an upper end job.  Because you are already doing 90% of the work to replace the head gasket, I would pull the jug and hone it and install rings at the same time.  only adds about $60 to you rebuild and makes sure your engine is good and fresh when you put it back together.  Of course the added expanse is for the rings.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #5 on: August 24, 2012, 04:47:24 AM »
Even if I am seeping oil near the bottom seal?
Gus, Austin, MN.
Offline jtb
  • An unlikely
« Reply #6 on: August 24, 2012, 05:58:44 AM »
ThreeBond 1104 to re-seal the cases.
1977 CB750F
1985 V65 Sabre
