Author Topic: leaky head gasket I think  (Read 1759 times)
Offline wardenerd
  • '77 550F '81 650C
« on: August 28, 2012, 03:14:47 PM »
my 81 650C with 9000 miles, It has a leaky head gasket I think.  I cleaned the fins and put flour on the fins and discovered after running it that there is a one half inch wet spot in the center of the seam between the head and the lower case on the left side of the engine.  Is there any way to stop this leak without a new head gasket?  I run 10W30 rotella synthetic .  The leak stopped for about a month after I went on a long trip to the mountains at a constnt 60 to 70MPH but now it is back.  The leak is more ugly than anything else.  Otherwise the bike runs flawlessly.   I ride it to work almost everyday 34 miles round trip and it is mostly city stop and go.I  Add oil when the stick gets down to half way on the dip stick.  A few ounces tops it off. Can I do anything to help the situation?
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: leaky head gasket I think
« Reply #1 on: August 28, 2012, 03:26:43 PM »
Get some nylon rope that will fit in between the fins and shove it in there to create the Oil Tampon. Seriously. Then just keep it topped-off. Not worth the effort/expense to fix on an otherwise-well-running bike IMO.
Offline goldarrow
  • one day, i'll be an
« Reply #2 on: August 28, 2012, 04:07:33 PM »
Time for sourcing a used, good engine....if you ever, I want your camshaft :) j/k
- its either live with it
- retorque the head down
-change gasket, if you go down this road, might as well freshen up or rebuild  the top end altogether.
CB550 K0
Offline trueblue
« Reply #3 on: August 29, 2012, 04:06:48 AM »
I found when I was running 10w40 synthetic my 650 leaked quite bad, I changed to 20w50 mineral oil and it all but stopped leaking.  The only leak I had to fix after this was the o-rings in my oil pump.  It still has a slight oil leak around the head gasket, but it isn't a dripping leak, it is only a light film of oil that holds a little dirt, I can live with that.  At least until I fit my wiseco overbore kit to it ;D
1979 CB650Z
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #4 on: August 29, 2012, 04:54:54 AM »
Are there any aide effecta running 20W50?
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline dhall57
« Reply #5 on: August 29, 2012, 05:14:19 AM »
I agree Tug. Wardender both my 750's seep a little, but the K6 is the worse of the two. But still not anywhere bad enough to pull the engine to fix. I use small rolled up sections of paper towels between the fins and even paint them silver and there hardly noticeable. Works great!
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline trueblue
« Reply #6 on: August 29, 2012, 05:23:12 AM »
I assume you mean side effects, other than using less oil mine also now shifts smoother, I can find neutral real easy at a stop, just touch the shifter and it clicks into neutral.  Where I live it is fairly warm, the very coldest we get here is 2-3C and there are very few days a year I don't ride because it is too cold.  In summer we are pushing mid 30's C .  Only on the very coldest days it is a little stiff going into gear first thing in the morning.
1979 CB650Z
