Author Topic: homemade NOT A REAL ultrasonic cleaner  (Read 8538 times)
Offline luap
  • LAWL
« on: September 10, 2012, 04:56:33 PM »
« Last Edit: September 12, 2012, 02:36:31 PM by luap »
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
Re: homemade ultrasonic cleaner
« Reply #1 on: September 10, 2012, 05:26:34 PM »
I use a small ultrasonic cleaner at work, and the vibes come from the bottom center. I would try it like that. Would have liked to see a clean solution with a dirty item going into it.
Bla bla
OK. Get a clean bucket, fill it with warm water and whatever degreaser you prefer, put the sander so it vibes from the center bottom of the bucket and....drop your dirty ish in there. (all on video of course)
Offline luap
  • LAWL
« Reply #2 on: September 10, 2012, 08:03:49 PM »
Went to walfart bought a 5 gallon plastic bucket an a 24.00 black an decker sander 13000spm
filled it with simple green an degreaser ratched the sander to the bottom an hung it from the ceiling.
did a couple bowls to start an Not 100% clean but a def 90%. will go over them with some carbs cleaner an compressed air when I pull them out. total 31.00
www.cb-town.com
« Reply #3 on: September 10, 2012, 08:20:27 PM »
frigging brilliant.
Offline luap
  • LAWL
« Reply #4 on: September 10, 2012, 10:08:10 PM »
I think If i would have used hotter water it might have cleaned a little more. think I will try a heating element through the lid tomorrow
www.cb-town.com
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #5 on: September 11, 2012, 10:44:12 AM »
Here is another one:
how a redneck inventor cleans carburetors part 1
But I have yet to see a before and after pic of a carb actually cleaned by one these redneck parts cleaners.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #6 on: September 11, 2012, 01:32:53 PM »
HA!i just found a good working palm sander in a bin,,guess what im going to do with it now?
strap one to your fish tank and have really clean gold fish?
« Last Edit: September 11, 2012, 01:35:12 PM by dave500 »
Offline mrrch
« Reply #7 on: September 11, 2012, 01:45:30 PM »
Self massage?? :o
my build
Offline singedebile
« Reply #8 on: September 11, 2012, 03:18:31 PM »
thanks for sharing that could certainly be useful!!
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
Offline 74cb750
« Reply #9 on: September 11, 2012, 04:24:14 PM »
Interesting, but I also would like to see a dirty carb first,
then the after picture before I would try this.
The concept sounds logical, but does it really work?
Laugh at least once a day.
Life  $ucks, then you die.
Offline luap
  • LAWL
« Reply #10 on: September 11, 2012, 05:02:14 PM »
Drop my pistons in for 20 minutes came out pretty good. Heat helps alot
www.cb-town.com
Offline CBGhia
« Reply #11 on: September 11, 2012, 06:18:33 PM »
I will be trying this this weekend.  I have the required equipment!   ;)
Offline 74cb750
« Reply #12 on: September 12, 2012, 07:23:07 AM »
Hey Luap,
when you say "heat helps a lot"
did you try it cold first?
What and how did you heat up the solution?
Offline kirkn
« Reply #13 on: September 12, 2012, 08:06:13 AM »
Hmmm.....
I'm thinking that the sander vibrations do absolutely nothing at all in terms of simulating ultrasonic cleaners.
The ultrasonic cleaners work, IIRC, by creating microscopic cavitation bubbles and when those bubbles form & collapse, they remove a particle of contamination from the substrate (base metal) with them.
A palm sander strapped to the outside of a bucket does no more than a good vigorous stirring would, IMO.  I'm thinking that any cleaning activity seen here is strictly because of the liquid cleaner itself, along with the heat, as mentioned.  I don't think there's any "ultrasonic" action at all.
Ultrasonic cleaners operate at frequencies between 20,000 ~ 400,000 Hz.  A 13,000 rpm sander is operating at 13,000/60 = 217 Hz.
So, I'd call it a "homemade agitator" not a "homemade ultrasonic cleaner".
Offline luap
  • LAWL
« Reply #14 on: September 12, 2012, 08:59:21 AM »
Yeah I tried it cold the other day when I put it together dropped my carbs in. It cleaned them. I did the heat yesterday on the pistons b/c the carbon was built up pretty good, I took a heating pad an wrapped it around the bucket as much as it would go. Im looking for a 5 gallon bucket band heater or ill go 5 gallon metal bucket an do a heating element.
This thing makes some bubbles, Theres no comparison between a real USC an this thing. but If you want to save yourself alot of scrubbing an cans of cleaners this thing works. I can say in the past Ive used the same solution in just hot an cold water an it doesnt do anything
www.cb-town.com
Offline Roach Carver
« Reply #15 on: September 12, 2012, 12:04:24 PM »
Hmmm.....
agreed. The only way to check this would be to use to simillarly dirty carbs, one in the solution with the sander and one in the same solution without agitation for same amount of time. remove rinse and compare.
Offline HondanutRider
« Reply #16 on: September 12, 2012, 12:51:55 PM »
Hmmm.....
...or a more complete comparison would be comparing to an actual USC.
Offline 333
  • Time for change
« Reply #17 on: September 12, 2012, 01:23:38 PM »
One of you guys who are trying this need to do a comparison test by using the same solution, and doing it without the sander.  We need to know if the vibrations are really doing the job, or if it is just the solution.
And FYI, this is not "ultrasonic".  True ultrasonic happens at a much higher frequency.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline luap
  • LAWL
Re: homemade NOT A REAL ultrasonic cleaner
« Reply #18 on: September 12, 2012, 03:01:41 PM »
doing a test.
2 seperate 5 gallon buckets both with with hose maybe a gallon water both half cup of degreaser
2 750 bowls
bowl on left worse of the two in the bucket with sander on bottom
bowl on right  sitting on garage floor
put them in at 2:50 let them go for 20 minutes
ill snap a couple after pic when there done an also the water
www.cb-town.com
Offline imabass
« Reply #19 on: September 12, 2012, 03:04:54 PM »
Interesting idea but not sure it will do the same job.  I have several videos on YouTube for cleaning carbs via ultrasonic cleaner with vinegar
ttp://www.youtube.com/watch?v=N5LD_oTnqYI&feature=youtube_gdata_player
Offline luap
  • LAWL
« Reply #20 on: September 12, 2012, 03:37:57 PM »
so after 20 mintues
didnt really break up all the old gas in the bowl(possibly need a better solution to break up that old of gas) but the outside of the carb grim is much better
I just had a buddy tell me about vinigar think Ill give it a try
anyways If anything It just saves some time on elbow grease
I agree I dont think it will or does the same job as a real machine but for 30 bucks it was worth the money
« Last Edit: September 12, 2012, 03:39:40 PM by luap »
www.cb-town.com
« Reply #21 on: September 12, 2012, 04:26:33 PM »
Simple Green will cut through the gum. Get a clear plastic container used for take out Chinese soup and drop two of them them in there for an hour. Full strength works best.
« Reply #22 on: September 12, 2012, 05:16:00 PM »
Simple Green will also dissolve aluminum. :P :P :P :o
« Reply #23 on: September 12, 2012, 05:28:14 PM »
Maybe, but not in an hour.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #24 on: September 13, 2012, 10:39:32 AM »
So will vinegar if you left it in for a month.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
