Author Topic: cb550 oil pump cover o ring  (Read 6535 times)
Offline lefty2023
« on: September 20, 2012, 01:32:40 PM »
hello, i cant seem to find a replacement o ring for the oil pump cover.  honda doesnt sell it anymore.  ive tried several random o rings that ive found at local stores and didnt have any luck.  its the o ring that sits behind the 3 phillips screws and before the rotor. any suggestions?
77 cb550k and 77 cb550f
Offline DustyRags
  • I'm not skilled, I'm just a
  • Just try it and see what happens
Re: cb550 oil pump cover o ring
« Reply #1 on: September 20, 2012, 02:05:28 PM »
They're still available from Honda, but not as what you think. The o-ring for the oil pump cover is sized 46x2mm. Honda's part no is 91305426003. It's been used in CB350F (seal between cylinders and lower case), CB650 (same as CB500/CB550: oil pump cover), GL1000 (water pump). You can still order it as the Goldwing part.
The reason it's not available as the oil pump seal is because Honda just sold the whole oil pump as a unit, and never intended it to come apart- if you look in the Clymer manual, you'll see that they have the original Honda drawing with the pump removed but still in one piece, and then also have a photo of the whole pump taken apart, which Clymer took. In Honda's parts list, the pump is listed as one unit.
Get the Goldwing seal, it'll work fine. I did this a couple of weeks ago with no problem (whole build thread here, if you care: http://forums.sohc4.net/index.php?topic=110973)
1976 CB550K- sold
2005 Kawasaki Vulcan 500- sold
2000 CB750 Nighthawk - sold
1975 XL350 - crashed
2004 Suzuki Vstrom 650 - sold
Offline lefty2023
« Reply #2 on: September 22, 2012, 06:32:16 AM »
awesome, thanks!
Offline onepieceatatime
« Reply #3 on: September 22, 2012, 09:46:54 AM »
Also available from McMaster-Carr, Part number 4061T178.
It is a 1.737" ID, 1.943" OD 0.103" thick square o-ring.
"The square cross section on these rings retains a seal longer than standard O-rings, especially at higher temperatures and pressures. Interchangeable with AS568A O-rings size for size. Buna-N is for use in oil applications. Temperature range is -30° to +212° F. Durometer hardness is A70. Color is black."
http://www.mcmaster.com/#4061T178
I bought the bag of 50. PM me with an address, and I'll send one your way.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline spdygnzlz
« Reply #4 on: June 25, 2014, 11:06:42 AM »
I know this is an old thread but curious about how those o-rings from mcmaster held up.  I have the same leak on my cb550 and am sourcing the o-rings...
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« Reply #5 on: June 25, 2014, 05:03:50 PM »
Honda part # 91305426003
Sorry had to edit.
46x2 oring
I just put one on my leaky oil pump.
« Last Edit: June 26, 2014, 04:31:32 AM by DavePhipps »
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Maurice
« Reply #6 on: June 25, 2014, 06:39:15 PM »
They work fine my pump hasn't leaked.
I still have a few, PM me if you're interested.
Offline spdygnzlz
« Reply #7 on: June 27, 2014, 09:39:58 PM »
found a set that included the 46x2 o-ring on ebay.  we'll see how it looks when it gets here.  it's the only place i've had an oil leak since my rebuild.
Offline Dave Voss
« Reply #8 on: June 28, 2014, 08:22:56 AM »
This is what I used to replace my leaking oil pump O-ring, 2x46mm 75 durometer 75 Viton, McMaster-Carr # 9263K665.  There is also a Buna-N version in the same size, but I recommend the Viton since it has a higher temperature rating, and tends to retain its shape better under pressure to prevent pre-mature compression and leaking.  They are sold in packs of ten, which is fine since the cost is low (~$15 per pack) and you end up with lots of spares.
-Dave Voss
(past) '78 CB550K4
(past) '75 CB550K1
(now) '95 R1100RSL
Offline Way Way norcal
« Reply #9 on: December 19, 2015, 12:10:54 PM »
do you have to drain the oil to remove that oil pump cover on a CB 550?
Offline neurotoxin312
« Reply #10 on: May 30, 2017, 07:41:16 AM »
Anyone have any spare O rings left over? I figured I'd check here before ordering a pack of 10 from Mcmaster lol
Offline GardenGnome
  • 1977 CB550F
« Reply #11 on: May 30, 2017, 04:37:34 PM »
Contact memberr Elan. He sells oil pump rebuild kits for a fair price. Has everything needed.
If I've learned anything about building a motorcycle, it's check and re-check your work before you put it all back together. Although you do gain more experience by doing it twice.
